Greetings, I have a Chieftec server whihc has been running just fine. Hwever, yesterday it started a beep beep beep, and it has not stopped since. It is coming from inside the server (O/S = Windows 2003). I even shut it down, but when stated back up, the beep beep beep came back on. It continues to run fine! Thanks, Don C.
    President:
  • 1,197 Answers
Do you have diagnostic lights or anything on the machine itself?
Or do you have tools from the manufacturer to check the hardware status?
Sounds like the beep is from the BIOS and therfore probably hardware related.
Is it actually working at all?
If you can, replace the network cable and see what happens, or change the port on the switch it connects too, if you can that is.
if that doesnt help
there are 3 things why ur servr will beep..... the server may beep if it gets hot..... but i presume ur beeping shud be caused by RAM... take it out and reinsert ur RAM and IDE card/video card... if it still continues either ur RAM or the IDE card is dying... u might need to replace them.....
if all the above fails... u will have to call chieftec........
if u feel my service was helpful... kindly rate my solution.....
good luck..... and have a nice day Don
Posted on Jun 16, 2009
Good day, dear Experts :) My MB is an Asrock 775 VMS with WinXP SP3 , Intel Celeron 2.8 GHz , 2G RAM , PS Chieftec 500V. I use the motherboard's AGP slot for VC, preferring various Radeon cards, like...
The HD4650 is a power hungry card. If the entiresystem refuses to start, then the power supply may not be able to run the configuration.
Of course, this is just a possibility, or your card is just damaged.
Mar 11, 2011 | Asrock 775VM800 Motherboard
Micron Netframe 3620 server running server 2003 with raid drive has steady beeps at start up that never stops and says it can not find drive. Where do I start looking for problem?
on the hard drive carriers themselves there are LEDs that will be amber in color to indicate which drive has an issue. You can also install MegaRAID Storage Manager in Windows to view the status of the drives
Feb 09, 2011 | MPC Computers Netframe 3620 Server
Ooops link appears to be broken...
the sentence "link appears to be broken" occurs with respect to "busy" status at server side and at that we are in queue for server support link, we need to wait for our turn! or You may running download software which some times does not allow other parties to use net line.
Have patience, you are going to get desired one since there may be request like from your side! have fine Xmas and greetings from my side
Dec 17, 2009 | Facebook Social Network
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Mar 09, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Dell PowerEdge 1600SC Server occasionally beeps when running
Check out this site:
http://bioscentral.com/postcodes/dellbios.htm
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Sep 26, 2008 | Dell PowerEdge 1600SC Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
27 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
