Question about Sony Playstation 3 (PS3) Console
Have had psp3 hooked up for 2 years, set up on video 2, with direct tv it has now started flashing no signal.
PS3?????PSP????????PSP3000???????I assume its a ps3, probably(if you use an HDTV) you have 1-3 HDMI,,or component,or composite(standard) (I have 2 of each) In which your direct TV might be taking it...... OR if you have an animal or infestation check your cables to see if something on the tips is bent or the cable chewed up.......this is all i could think of...
Posted on Jun 16, 2009
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Nov 19, 2010 | Samsung Audio Players & Recorders
I have a technics sa-dx930 receiver and want to hook it up directly to the tv without running it through the dvd/vcr... How would I go about setting it up and what cables go where... Sorry woman here not...
It would help to know some details about tour TV - like its make and model. Or do you mean the CABLE BOX?
And there are TWO signals to consider - audio and video. WHICH is the one you need to hook up without involving the dvd/vcr?
Let's start with basics:
1) TV's are not audio sources. They are end-units for video and its medium-fi audio.
A TV's internal audio capacity is more a convenience for stand-alone listening than a serious approach at hi-end audio. Many of us have monitors with NO audio capability.
TV-related audio and video are best VIEWED via direct video connection to the TV; and HEARD through direct digital audio connection to the receiver.
2) The one NECESSARY connection you need from the receiver to the TV is the basic VIDEO that let's the receiver communicate with you through the TV.
Jun 06, 2010 | Technics SA-DX930 Receiver
How to hook psp3 to regular tv
The ps3 has 2 ways to connect to your tv. It has HDMI output and a regular video output. The regular video output is a yellow RCA connector with a red and white audio connector. You should have gotten this cable with the ps3. If your tv does not have a video or AUX input a regular vcr will. Connect the yellow, red and white from your ps3 to the same on your tv or vcr and select that input on your tv or vcr.
Feb 07, 2010 | Sanyo DS31520 31" TV
I have a 50 in vizio plasma. just hooked up a psp3 for the blue ray, but the input only says 480. What gives? shouldn't this be 1080? I can't find an ajustment on the menu screen on my tv?
What you need to do is hook up your PS3 to a different tv. Then in Display setting on the PS3 change it to 480p. Hook it up to your vizio and while on the ps3, change it back to 1080p. Most Vizios don't have a Progressive scan that adjusts to the output settings of the PS3 (or other device) .
Apr 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Sony Playstation 3 (PS3) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
