Question about Tissot T Touch Navigator 3000 T96.1.488.42 watch
Digital and analog times are different
The analog portion is an hour and 15 behind the correct digital time. Not sure what that does for my other functions like the compass
  • 58 Answers
Adjust the analogue time with the winder
Posted on Jun 22, 2009
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
Half hour lag
Some watches can display dual times (two values) usually off by an integer number of hours + 30 minutes, Read the manual to set the digital display time then correct the analog display. Or just use one of the two.
Oct 15, 2013 | Casio Edifice Watches
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
I have the correct time set in the watch, the main analog clock shows the correct time, but the UTC analog hands19:00 when the UTC digital time is 12:00. How do I reset the UTC analog hour hands?
The hands are driven by the digital. It seems to me you have the wrong digital city. Please review the setting instructions for your Skyhawk at: http://www.citizenwatch.com/
BTW, I love my Titinimum Skyhawk
Aug 03, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
The digital time and the analog time are not synchronized
Here is complete manual for your watch:
http://www.t-touch.com/t-touch_images/usersmanual/140-en.pdf
If you are not successful with this, maybe it's time to change the battery?
Read manual carefully and you will find out how to recognize: I'ts time to change the battery.
Rate me, please.
Apr 04, 2009 | Tissot T Touch Navigator 3000 T96.1.488.42...
Setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Dec 03, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Tissot T Touch Navigator 3000 T96.1.488.42 watch Logo
403 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
