Question about Sony Handycam CCD-TR517 Camcorder
Ccd tr517 Hi. I have this Handycam and it isn't so handy. We have never been able to figure it out. It shuts off after a few seconds. We bought a brand new battery and it still does it. Any advice? Thanks
Re: ccd tr517
I had the same thing on mine and it turned out to be the on/off switch in the lens head. I took it apart and moved the switch a bit and the problem did not come back for quite awhile. I replaced the switch and it has been fine.
My camera would actually turn on by itself also before changing the switch.
Posted on Jan 02, 2008
0 characters
3 Points
I need the software for CCD TR 517
I understand that you wish to transfer recordings from the Camcorder to the a computer. Since the CCD TR517 is an analog Camcorder, driver and software from the manufacturer is not required to transfer videos. You can connect the A/V output of the Camcorder to the A/V input on the Computer and use the Windows Movie Maker software available with the Windows Operating System to capture the videos. Please let me know if you require more details about doing that.
Thanks for understanding.
Apr 23, 2011 | Sony Handycam CCD-TR517 Camcorder
Can you get a new side window for tr517 where time and battery capacity is shown?
You may be better buying another broken one - to use for parts. It should be a lot cheaper.
Dec 27, 2010 | Sony Handycam CCD-TR517 Camcorder
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
Sony Handycam does not turn on Model # ccd-tr517 ntsc
Try this link to troubleshoot this issue.
Aug 06, 2009 | Sony Handycam CCD-TR517 Camcorder
Handycam CCD TR517 Doesn't record
These models have a switch for 3 different modes of record. one where you press the red button once, one for having to hold the red button in and a 5 second record feature, check this mode. also check and make sure the tape you are using did not have the record save switch slid into record save position..
Jul 20, 2009 | Sony Handycam CCD-TR517 Camcorder
Zoom button doesn't zoom lens
Most likely it will need a zoom switch block assembly if it's located on the top of the unit the part number is 1-418-760-21 and has a list cost of $38.40 Andrews Electronics has these. call : 1-800-289-0300
May 22, 2009 | Sony Handycam CCD-TR517 Camcorder
Transfering 8mm video tapes to dvds
Hi there. You need to transfer your videos to your computer and then burn them to DVD using a program like Record Now, or Nero. You should be able to get this from Best Buy, or you can get it online from their websites. If you have any other questions, let me know with a comment. Thanks for coming to FixYa.
Mar 03, 2009 | Sony Handycam CCD-TR517 Camcorder
My ribbon cable broken
I can give you its part number if you paste picture of desired cable showing its position in Sony camcorder CCD-TR517
Aug 01, 2008 | Sony Handycam CCD-TR517 Camcorder
How do that the image is blask and white?
Dear Sasanka,
I think CCD-TR517 is more then 10 years old and it has hardware problem i.e capacitors in camera got weaker and need to be replaced all of them.
May 25, 2008 | Sony Handycam CCD-TR517 Camcorder
Sony Handycam CCD-TR517 Camcorder Logo
74 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
