Question about Nokia Cell Phones
Hi.i have a nokia 3330.when i switch it on it first 'says sim card registration failed' and it then asks for the security code which i have forgotten.can any1 help pleez?
  • 106 Answers
SOURCE: SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
Posted on May 08, 2009
SOURCE: FORGOTTEN MY SECURITY CODE 4 NOKIA 6230!
FORGOTTEN MY SECURITY CODE 4 NOKIA 6230! MY IMEI IS 356952/01/01184880/3
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: Problem nokia 6300 ( Sim card registration failed )
i want to know that this problem solve
Posted on Dec 29, 2009
  • 1456 Answers
SOURCE: Nokia 6500 slide sim card registration problemit
Hello
There are two things causing this problem,either your phone is not registered to the Sim card's network or your Sim card is corrupt
To find out where the problem has come from,you should try another Sim with your phone, if the Sim does not work then the phone is registered to a particular network and no other Sim card will work on it.
If you try another Sim card and it works then your Sim card is corrupt and you should replace it.but to be double sure,test the Sim card on another phone to see if it works,if it does then your phone is not compatible with the Sim card's network but if it does not work then your Sim has to be changed
thank you for visiting fixya
Posted on Jul 27, 2010
SOURCE: nokia 95 8gb china , showing invalid sim or sim
I have brought a china mobile CITYCALL U800 from DUBAI TO MUMBAI now i am facing problem invalid sim,i am a vodafone user
Posted on Sep 03, 2010
Nokia 6300 SIM card registration failed
If your Nokia 6300 phone displays an error message saying "Invalid Sim (or) Sim Registration failed" then your phone is probably network locked.
You can unlock it easily by using an unlock code.You can get this code at reasonable cost from TheUnlockArena.com with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network Sim card.
Dec 31, 2013 | Nokia 6300 Cell Phone
Hi, I have bought brand new nokia 7230. when ever i try to enter any sim it says sim card registration failed. Please tell what is exact reason and how to solve it and make my phone work.
Insert any sim and try using these codes #pw+123456789+1# #pw+123456789+2# #pw+123456789+3# #pw+123456789+4# and follow onscreen instructions
May 04, 2011 | Nokia 7230 Cell Phone
Hi.... i am using nokia 2690 how to lock the cell with password ???? plz guide me sir :(
Select Menu > Settings > Security and from the following options:
  • PIN code request or UPIN code request-to set the phone to ask for your PIN or UPIN code every time the phone is switched on. Some SIM cards do not allow the code request to be turned off.
  • Security level > Phone-to set the phone to ask for the security code whenever a new SIM card is inserted into the phone. If you select Memory, the phone asks for the security code when the SIM card memory is selected, and you want to change the memory in use.
  • Access codes-to change the security code (default code is 12345), PIN code, PIN2 code, or restriction password.
Jan 16, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
My phone keeps saying sim card registration fail and i don't know what to do
hi...
I belive you got a new sim card.sim card registrations fails comes only when the delear from whom you purchased might havent gave your proff to the service providers. so please contact the delear from whom you got the sim card.
thanx
Jul 15, 2010 | Nokia 5310 Cellular Phone
Check that sim valid,
Check with another sim card if problem not shows sim card may complaint do as follows
Take the sim crd out and rub gently with a cotton cloth, and reinsert it.
Or take to service provider & ask him to give duplicate sim.
If problem with mobile try to dial *#7370#(Format),
Or take mobile to Nokia care(Problem might be network ic).
Sep 29, 2009 | Nokia N73 Cellular Phone
Unlocking code for nokia n70
(First: copy all contacts from the phone to SIM card)
1.Switch off the phone.
2. Press and hold the following three buttons:
Green(call answer) button, (*) button, (3) button.
3.Now press the switch on button.
4.Then the message 'Formatting" appears on the screen release all buttons. I hope this can assist you in the fix .
Sep 05, 2008 | Nokia N70 Cellular Phone
Sim registration failed
most of this nokia phone(the old ones) do often experience such problem due to it's constant falling on the ground.
in such cases after restarting the phone the problem should be corrected for a while...............using a NEW sim card and practically the one of a network with the strongest signal does in most cases rectifies the problem a bit.
all the same i would ask you to send it to a phone technician for more help.
good luck
May 29, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
48 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
