When i lay down the cpu , the cpu fan is running otherwise not
    President:
  • 828 Answers
Try to clean the fan or check it if theres some dusk in your fan and check also wires if theres a loss contact to to power
Posted on Jun 16, 2009
Fan blade cracked
Replace it. Warranty if still in time and not due to bad installation or error. New purchase otherwise. Do not run the fan with a cracked blade or the computer without a fan.
Feb 12, 2014 | Antec KUHLER Shelf 120 mm PWM fan...
How to upplug fan in desktop
How to Reduce the Noise of Your CPU Fan
The CPU fan is what keeps the processor of your computer cool while the machine is running. A noisy fan on the CPU can be very annoying for users of the computer. However, it can also be a sign of a dangerous problem in your system. If the CPU fan is making noise, it is probably not running at full capacity to cool the processor, which leaves your computer open to problems involving overheating of the processor. An overheated processor can be permanently damaged.
Step 1
Unplug the computer from the wall. Remove all devices from the back of the computer and move them away from the area where you will be working. Either wear an anti-static wristband or discharge any static by touching a metal part of the computer case.
Step 2
Remove the screws from the back of the computer case with a screwdriver. Pull the sides of the case off and set them aside. Lay the computer on its side so that you can easily see the motherboard and all parts connected to it. Locate the CPU fan; it will look similar to the image in the introduction.
Step 3
Ensure that no cables are hanging low and touching the blades of the CPU fan. Move any cables or other parts that could be hitting the blades of the fan causing noise. Tuck these cables and wires into an area where they cannot interfere with the CPU fan.
Step 4
Use a cotton swab to remove any dust that you can from the blades of the CPU fan. Don't use any harsh solvents or other cleaners that could drip down and damage the processor through the fan.
Step 5
Spray the compressed air into the fan to move the loose dust away from the processor fan. Move the dust into an empty section of the case with the canned air. Don't spray the air too hard or else you can spread the dust into other places in the computer.
Step 6
Use the vacuum cleaner to vacuum up the dust that you moved away from the CPU. Place a crevice tool or other attachment onto the hose to reduce the size of the opening and help ensure that you only remove dust.
Step 7
Replace the computer case. Plug the computer and all devices back in. Boot up the computer and check for reduced CPU fan noise.
Oct 31, 2012 | HP Computers & Internet
My Toshiba Satellite 1905 When You Power On, It Shuts Off Right Away. You Can Here The Fan Run But Shuts Down.
Make sure the CPU and the CPU heat sink are both properly seated - otherwise the "desktop" CPU overheats almost instantly and shuts down the computer. At the bottom of your 1905, the CPU heat sink is located underneath the smallest door and held in by 4 small screws at the corners.
That ought to do it.
Jan 02, 2010 | Computers & Internet
Computer runs when cold, dies as soon as it gets near room temperature. To get it cold I leave it outside at night or in the deep freeze.
Most people complain about their computer freezing up.
You have components that are entering the failure stage, once the computer sensor reports heat it shuts down. Check that you have fan activity, this is the first line of diagnosis. Otherwise its one of the power chips on the motherboard and is a replacement job with a high cost. Fan replacement is cheap by comparison.
Please rate my help++++Thanks for using Fixya
Dec 05, 2009 | Dell Inspiron 6000 Notebook
My computer freezes when the fan motor runs
You probably have a bad power supply. When the fan turns on it may be consuming what little extra power you have available. Check the electrical connections in your PC, if they are good, then you need to replace your power supply.
Nov 01, 2009 | E-Machines eMachines Desktop PC
I need fan/heat sink anchors for 775 cpu. nylon tips broke off letting fan pull away from cpu can I buy the anchors only. desk pc is custon built.
If you have another heat sink laying around, perhaps in an old computer you don't use? Try using the anchors from that.
I have also had success mounting fans to heat sinks using wire ties. Not sure that will work with your problem though because it seems you're talking about the actual gadget (usually a piece of metal) that locks the heat sink down onto the CPU.
Aug 23, 2009 | Computers & Internet
The cpu fan wont run--i cleaned it with air can--if i hold the start button down it will stay running but make a lot of noise--when i let up on the switch it will die--i think the cpu fan burnt out causing...
Try replacing the fan first, and see if the computer starts, and runs normally, otherwise you could have fried the CPU. In that case a new processor is needed.
Aug 04, 2009 | ASUS Computers & Internet
Help my computer wont start if I close my lid ....
It sounds to me that there might be a lose connection somewhere. The first thing to do is make sure that all cables are securely fastened.
When you say that your computer won't start when you put the cover back on and lay it on it's side does it respond at all when you hit the power button? Lights, anything displayed on the monitor, fan noise, etc.? Also when you leave the cover off is the computer laid on it's side like when the cover is on? does it work laying on it's side with the cover off?
MO
Jul 13, 2008 | Acer Veriton 3600GT PC Desktop
Cpu fan starts then stops
Replace it and let us know if it still happens with the new one.It shut down because of overheating, I hope it didnt mess up your CPU.
Jan 06, 2008 | Biostar GEFORCE 6100-M9 Motherboard
My AMD X 2 4000+ Windsor is overheatting
Hi, you shouldnt even switch on the PC if its running at that temperature, machine will be restarting and shutting down on you.
If you just bought it, you should take it back to the shop.
Otherwise you need to remove the old heatsink and fan and apply new thermal paste to the cpu and resit the heatsink, if its still running very hot over 50c you will probably find the cpu has been damaged.
Have a nice christmas
John
Nov 21, 2007 | AMD CPU Cooler Fan + Heatsink for up to...
Computers & Internet Logo
50 people viewed this question
Alun Cox
David Payne
David Payne
