Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No electric I turned the mower off. When I tried to start it again no electric to starter, or lights. Battery is charged. Is there a fuse that could have blown andwhere is it?
There's a 20 AMP fuse hanging under the fuel tank on the right side of the tractor. I just bought 5 from Auto Zone for $3. Hope this helps. derek
Posted on Jun 23, 2009
I hooked the new battery up backwards and it won't turn over now...
Tullio, hook the battery up correctly, check for blown fuses,etc.
Apr 17, 2016 | Garden
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
2005 GMC Yukon XL will not start. Took starter off and had it tested. The starter is good. However, the PCM fuse is blowing when attempting to start truck or turning turning the switch to start the tr
There is a dead short to ground on that circuit . There are videos on youtube showing how to find an fix a short . Do you know how to do automotive electrical testing ? How to find automotive electrical shorts Look at the wiring harness under the hood for rubbed through wire's , harness going to the PCM , also find out what if any thing else is powered by that fuse . Which PCM fuse ? There are a few PCM 1 , PCM B , etc...
PCM 1 Fuse
15A
Powertrain Control Module (PCM), Mass Air Flow (MAF) Sensor, Evaporative Emission (EVAP) Canister Purge Solenoid, Fuel Composition Sensor, Secondary Fuel Pump Relay
PCM B Fuse
20A
Any one of these fuse will cause the engine not to crank . The PCM energizes the starter relay which supply's power to the starter .
Mar 11, 2017 | 2005 GMC Yukon XL
Nissan Altama Starter Relay electrical problems or a fuse?
Or the battery cables ! Do you know how to use a voltmeter ?
Starter Voltage Drop
Do you know how to do basic automotive electrical testing ?
How to voltage drop test starter motor circuit
Electric Testing Techniques You Need to Know Here is a place to view wiring diagrams ! http://www.bbbind.com/free_tsb.html
Apr 08, 2017 | 2004 Nissan Altima
Double check the battery positive connection wiring carefully as it commonly has connection problems when the battery is changed.
Trouble with the battery would not hold charge. While driving car stopped. Tried jump starting no.go . Tried new battery car won't click over?
Double whammy. starter non operational and alternator doesnt charge. Hmm it has to just be one problem not two.do you have clean battery connections external part of the battery or internal part of the battery.concentrate your effort on the terminals and lets start this car.does the head light go on if yes . okay now turn the ignition did the battery just spark if it did you got a bad connection still okay now maybe you didnt turn the ignition did the light dim no okay you got a bad starter. tap the starter did it start or want to start. if it did youll need a starter. okay now that starter has a fuseable link is it blown or any of the omega fuse blown cause that will make a not charge and a starter not start. By the way the terminal that goes to the relay box and fuses is it making good contact?
Apr 22, 2011 | 2007 Suzuki Grand Vitara 4WD
I have an electric start. I charged this today for around 6 hours and there is no engagement what so ever. What should I do? Thanks
I wpold purchase a inexpensive volt/ohm meter or test light and procede to diagnose the problem, first I would make sure your battery did indead take a charge by using volt meter 1 lead to posotive, 1 lead to negative and see if it reads 12.50 or so volts, if that is charged, then if it is a push mower, it has a fuse right inside the battery box/cover by the deck of mower, check to see if you have 12 volts to each side of fuse(you will have to ground the black lead to batt negative black conn. and use red pos. lead to touch the fuse on top should be two bare spots one on each of fuse, if you have power on both sides, fuse is good,if only 1 side,fuse is blown, also check the connectors that fuse sticks in too these have a tendency to corrode and have bad connection,If alls good there I would go to starter and check for power on the heavy red wire when you turn the key to start should light up or show same voltage as battery does. any other questions let me know
Apr 18, 2011 | Toro Lawn Mower With Toro Power Tools
THE BATTERY I CHARGED BUT I GET NO POWER TO LIGHTS OR STARTER WHEN I TURN ON THE KEY, NO ELECTRIC FUEL PUMP HUM, NO NEUTRAL LIGHT ETC....
It sounds like the main fuse is blown, have you tried checking the fuses, I have seen them blow when the battery gets to low and it when you try to start it with a low battery is causes excessive draw and usually pops the fuse.
Apr 20, 2010 | 2000 kawasaki VN 800 Vulcan Drifter
Where is the fuse for Craftsman 17.5 HP 42 Riding Mower
I'm not sure the solenoid/relay would even energize at 10 volts (so you may not hear the clidking).
The battery is essentially dead at 10 volts -- try charging again for 4 hours or so, and then measure the voltage.
If it's not up near 12 volts, you have a dead cell and need a new battery.
May 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
04 chevy 2500HD start relay /Circuit braker turns off @ key crank
Make sure battery has a full charge and battery connections all good. Any fuses in the diagram, test for voltage, some are hot all the time, some go hot with the key on.
Use a digital multimeter across battery posts, everything off, the generic spec for a full charge is around 12.6 volts. Leave the leads hooked up to battery, have a helper turn key to crank, how far does it drop? In my opinion it shouldn't drop much under 10 volts, I wouldn't argue with 9.6 volts.
Mar 28, 2017 | Chevrolet 2500 Cars & Trucks
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
116 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
