It is not an router. The software only works on XP or Vista.
See Manual.
http://www.downloads.netgear.com/files/wn311t_user_manual_30jan07.pdf
SOURCE: Driver for NETGEAR PCI wireless adapter wg311
The answer to this issue is dependent on the linux distribution and version you are running.
There are several different versions of this card requiring different answers.
There are several different means in linux to address the issue. From earlier reading the NDISWrapper approach allows the used of a windows driver. For some versions of the card the madwfi project now on sourceforge, I believe may have options to support this card. -- see links below
Suggestions for each card version in this link
http://users.linpro.no/janl/hardware/wifi.html
the following show some discussions by others on this card
http://www.linuxcompatible.org/Netgear_WG311_c11290.html
Please confirm the Distribution and version of linux involved as well as the version of the wg311 adapter (1, 2, or 3) and I may be able to get more specific.
SOURCE: Netgear WPN111 wireless adapter won't connect
Is the computer Windows 98 SE [Second Edition] ?
What is the exact error message that you get ?
SOURCE: Netgear wireless adapter
In this case can you please tell me what is your wireless router and how may computer do you have so we can check if this is a problem with the wireless router or with the netgear wireless adapter. because if you only have 1 wireless computer so the problem here is with the wireless router we may need to change some wireless settings like the wireless channel .....
SOURCE: netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
