Check the link below. This should help http://www.fixyourownprinter.com/forums/printer/18540 Thanks Ranjit
It is not recommended that you clean the printhead manually. You should use the printers built in printhead cleaning from the menu. If that does not work replace the printhead. Usually there is a bay door in front on the sides or underneat the lid for the printhead. It may look like an ink cartridge
Using the Head Cleaning utility
Using the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
Note:
Refer to the appropriate section below to use the Head Cleaning utility.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that A4 or Letter size paper is loaded in the sheet feeder.
Make sure that this product is on and the ! Error light is off.
Access the printer software.Accessing the Printer Software for Windows
Click the Maintenance tab, then click the Head Cleaning button.
Follow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
Caution:Never turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
When Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
Note:
