Question about Nokia 6085 Cellular Phone
Screen goes blank
When I open my flip phone the main menu is on screen for about 5 seconds - then goes blank. I can't call out but I still get incoming calls - battery is full - was not dropped or damaged
  • 790 Answers
Hi
you have defective flex ribbon wire!
Thanks!
Posted on Jun 16, 2009
My lg vx8700 has only been used for a month and the screen goes blank on it about 7-15 seconds after I flip it open.
The problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
This is a common problem with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I will suggest you replace the flex on the screen of your phone to solve the problem.
If you cannot change the flex yourself, you can take the phone to a local repairer within your vicinity, so that the flex can be fixed or replaced.
Take care.
Jul 08, 2010 | LG VX-8700 Cellular Phone
Purchased in sept 2009 and screen went blank in oct 09.they replaced it and now its doing the same thing
can you still receive calls even when the screen is blank?
I don't think the screen is the problem of your phone, but a flex problem. This blank screen issue is a common problem with slide and flip phones.
This occurs as a result of constant opening and close of flip or slide phones which makes the flex to worn out.
The flex is the one that connects the screen to the phone main board, and once this flex is weak/worn out or loose contact, there won't be any display on the screen.
Therefore check the phone flex and not the screen. Screen doesn't just get spoilt, except it hits the ground or something.
Take care.
Mar 19, 2010 | Motorola Mobility Rival A455 Cell Phone
Screen goes blank when opening
Sometimes this problem happens when the wire for the screen get detached from the phone, or if the screen itself has a problem. It is common for flip phones to have this problem. To fix this problem, you need to take it to a repair center and have them reattach the wire onto the main board, which should not be very expensive.
Feb 25, 2010 | Motorola Mobility RAZR V3
Screen gets distorted and turns white
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Apr 25, 2009 | Samsung SPH-m520 Cell Phone
Nextel i880
my phone does not display menue anymore
Jan 15, 2009 | Motorola Mobility i880 Cellular Phone
Moto razr v3 is acting up
you need to reflash the phone
Oct 01, 2008 | Motorola Mobility RAZR V3
the flexcable need to be replace on the phone
Jun 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Camera gone blank
Hi,thanks for that. I tried that one, but it didn't work. It still had the same problem. I've now sent it out for repairs. Found it was still under warranty anyway. Thank you very much.
May 14, 2008 | Motorola Mobility W375 Cellular Phone
Motorola KRZR black screen
This URL explains that the blank screen is caused by a loose cable, includes instructions, and includes another URL that shows how to take the phone apart and re-seat the cable: http://www.howardforums.com/archive/topic/963501-1.html
I just fixed mine. The cable goes from the back of the phone (below the battery and SIM card) around the hinge and connects again on the flip-up part, under the screen. Re-seating at the main unit didn't fix it for me (dang), so I had to take off the cover on the flip-up part. Pretty hairy, but doable. You'll need TORX #5 and #6 screwdrivers.
I also saw where local repair shops will fix it for $75 (ouch), but that may be for a screen replacement--which is probably not needed. Opening and closing the phone is what causes the (tiny, flat) cable to need re-seating.
May 09, 2008 | Motorola Mobility RAZR V3
Nokia 6085 Cellular Phone Logo
154 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
