Question about Troy Bilt Tb70ss Gas Trimmer
My Kawasaki Trimmer is running bad. It will run
My Kawasaki Trimmer is running and idling bad. It will run but I can't get to full throttle. I cleaned the Carb really well Checked the gas lines and they also seem ok. Any help would be much appreciated.
  • dave580 Jun 16, 2009
    Hughie, Thanks I'll check the cables tonight.
  • 52 Answers
Check the throttle cable. You probably need to tighten it up. You will find it on the left hand side of the engine that is mounted it the top of the trimmer, thats where it normally is, but with the japanese you wouldn't know!! Have a look for it, won't be hard to find anyway. Also check the finger throttle. probably slack too.
Once you found the throttle cable at the top, find a optimum idling value and then tighten the cord at that point. (there should be an adjustable screw there.)
Hope it help's.
Hughie.
Posted on Jun 16, 2009
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
Added throttle and cuts out
remove the muffler and run it if runs good open the muffler and clean the screen
May 21, 2012 | Oregon Scientific Complete Carburetor for...
Have a Homelite mightylite 26ss String Trimmer. When i pull the trigger in the run position it cuts out and will shut off continuously. I checked the filter screen and it is clean(looks brand new). I've...
Let the engine warm at idle adequately before applying full throttle. With the engine warm, slowly bump the throttle and see if the response is good: if the engine wants to die again, let it continue warming at idle. If the problem persists, check that you are mixing your oil/gas mixture at the correct ratio: too much oil and you risk clogged the works.
Oct 07, 2010 | Homelite Mighty Lite Lawn Trimmer
Kawasaki khd 600A hedge trimmer just wont start.it runs for a second and stops
Bit late to help the owner of this question and yes it could be a carbie issue but also check the idle speed. If it has dropped out of calibration and is idling too low it will start then stop. Try starting with some throttle, keep it running if you can until it warms up then let the throttle go back to idle. If it stops check to see if opening the idle screw solves it.
Sep 24, 2010 | kawasaki Garden
Won't idle without choke, turn throttle boggs out
have u checked the float hight on the carburator? also make sure ur choke curcuit i clean and free of dirt
Apr 13, 2010 | 2005 kawasaki KLX 125
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Kawasaki KHT600S hedge trimmer cranks but won't throttle up
need a carb kit and a new fuel filter in the gastank
Aug 10, 2009 | Garden
Only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Jun 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
'04 Kawasaki KFX 700 idle problems from hard throttle to idle
1. Did you clog your airfilter with gas or anything else when you rolled it?
2. Did you damage the petcock or fuel control?
3. Choke cable stuck open?
Mar 30, 2009 | kawasaki Full Suspension Mountain Bike Men
Troy Bilt Tb70ss Gas Trimmer Logo
255 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
