Question about Proscan PS32600 32" TV
No channels I tried to connect my PS32600 with just the cable connector and I keep getting no Channels found. I do a channel search and then it doesn't save them. I switch TV's and the old still has all the channels but not the PS32600.  can you help.
  • globalmaa Nov 02, 2007
    Why would you need a cable box? If so what do you mean by cable box?
    Genius:
  • 1,694 Answers
The use of a cable box is, at the least, a diagnostic tool.....
A source "box" or set-top-box could be from cable company
or satellite service.If not available, a VCR tuner could be usefull.
Here is the procedure.....From the wall, hook-up cable lead into
"box" or VCR or DVD / VCR unit.....come out of that unit with
yellow video, red / white audio into yellow,red and white on back of TV. Select Vid 1 or Vid 2 on tv and leave it to test.....change chan's at source......What do you get........?........T.
Posted on Dec 08, 2007
  • 4,102 Answers
Are you plugging it into the actuall cable or is it an arial socket if it is the cable you need a cable box as you change the channels on this if it is the arial then it should have a self scan mode in the setup you wont get cable channels without a cable box because they opperate at different frequency and the newer tellt are made not to pick up these frequency so you have to purchase the cable box this should be plugged into your telly via a scart lead then you change the channels on the cable box the only channel maybe it is different as i live in the uk sorry i couldnt bbe any more help
Posted on Oct 31, 2007
How do I get channels
ok,if you have a subscription to cable,you will have a cable box,you will only need to put your tv on cable and ch 3 or 4 on your tv,you dont need to search for channels,if you dont have a subscription,then you are trying to pick up over the air channels,they are called digital channels,you will need a digital tv antenna and your hdtv,you will change the settings on your tv to air or antenna,then you can search for digital channels,there are no more analog channels like we had when we are kids,they are all digital and dont need to be tuned in,if you still cant get channels please have someone help you.
May 19, 2015 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
No program channel
The model listed here is a older set with a picture tube---One of its most common issues is a bad tuner which even with good signal will not pickup any channels.
What I would do is see if a VCR or DVD connected to one of the inputs for those on the rear works----if it does you can get around this problem with a cable box or sat box connected to one of the inputs other than the cable ones on the rear---select that input (they are numbered) and use the set that way---feed signal with a box and change the channels with that box.
Last time I replaced one of those tuners it was well over 150 dollars just for the part.
Dec 08, 2012 | Proscan PS32600 32" TV
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Programming
can you enter channel 4 manually and get picture
Nov 19, 2007 | Zenith Z19A11S TV
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Proscan TV Instruction Need
you wont be able to the high with rabbit ears antenna you will catch the low free channel.you need the cable to get the high channel.so it is est to connect back your cable good luck
May 06, 2007 | Proscan PS32600 32" TV
Proscan PS32600 32" TV Logo
242 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
