Question about HP LaserJet 5200 Printer
HP LaserJet 5200 PCL 6
My system is working in windows vista.
When i download the driver for hp lj 5200 pcl6, i got a winzip file.
when i am trying to install it it unzip the file and nothing more.
please help me how to install it
thank you
    Sergeant:
  • 199 Answers
Check where are you unzip file, and start setup from desination folder
Posted on Jun 16, 2009
Hp laserjet 5100 driver
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=74341&prodNameId=74343&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=lj-1423-8
Apr 04, 2011 | HP LaserJet 5100 PCL 6
I have some HP mf2727nf machines...I've downloaded the windows 7 drivers for the HP website, but can't get my windows7 laptop to work w/ this multi-function machine (I care mostly about printing. When I...
How to Select the Correct Printer Driver
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&prodSeriesId=3377075&prodTypeId=18972&objectID=c00751649
You can review the above but likely you wil want to choose to install the HP PCL 6 printer driver.
Personally I would opt to follow the first choice below:
Windows Download and Installation Methods There are 2 primary recommended methods for a Windows driver installation from the web: A) Using a specific driver, printing system, or other driver bundle from the Web Suggested download steps are as follows:
  1. Go to your product's software download page (e.g. www.hp.com/go/clj4700_software), or click here to go to www.hp.com/. Select your country/language, and then select Software & Driver Downloads .
  2. Select your computer's Operating System.
  3. Identify your driver (e.g. HP Color LaserJet 4700 PCL6).
  4. Select the Download button corresponding to your identified driver.
  5. Select Run (or optionally, Save , and double-click the saved file) to download the file.
  6. Select Run to uncompress and begin the installation.
  7. Follow the on-screen instructions.
B) Using the Windows Add-Printer Wizard with a specific driver downloaded from the Web
  8. Uncheck the "Help me install this driver?? (check box).
Dec 11, 2010 | HP Laserjet M2727nf Multifunction Printer
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
Getting System PCL XL Error
I think u have installed the PCL 5 or PCL 6 driver.Not to worry
Go to www.hp.com and download the PS driver for LJ 3055. Install the driver,u will not get the PCL XL error any more.
Thanks
All the Best!!!!!!!!!!1
Jan 08, 2009 | HP LaserJet 3055 All-In-One Printer
Can't print to old applications
The issue your having is with the Operating system compatability. The HP 3055 is compatible with 98, ME, XP, Window 2000 and forward. It won't do windows 3.1 or 95 well even if your computer will, the disconnect comes when the software is sending old print commands to a new style print driver.
Your best hope is to download and install the HP Printdriver for Windows 98 and try it as it's the most tolerant of old gear. Download the PCL 5 as the PCL6 is too new and probably not going to work.
As an alternate try to download each of the printdrivers for the differnt era windows and try them. It's a hard problem that may not have a solution other than upgrading the accounting software.
If it's simply a connection problem, they do make a USB to Parallel addaptor which may help you with the physical connection issue.
Here's a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=4&submit.x=3&lang=en&cc=us
Hope that helps you.
Aug 24, 2008 | HP LaserJet 3055 All-In-One Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
Pcl 5e driver for hp laserjet 1320
Make sure you can view filenames with the trailing dot and 3 letters so you can see the type of file. (Use tools menu, folder options, view, uncheck "hide extensions for known types") Doubleclick on the downloaded file and note where it is unzipping to (c:\lj something or other). Open that folder. Right click on the file ending in .inf and choose "install" in the menu that pops up. If that fails, open the control panel, choose Printers & faxes, rightclick on the HP printer, and choose "properties". Look for the "update driver" button, probably under "advanced". Help it choose that .inf file.
Sep 10, 2007 | HP LaserJet 1320 Printer
373 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
