Question about Boss Micro BR Digital Recorder
Burnt out my boss BR 1180. How do I repair?
I stupidly used my laptop charger to turn on my Boss br1180 and it burnt something inside. When using the correct mains adapter the screen flashes on then off after a sceond I just need to know who i can send it to for repair at a fair price. Or what I would need to do to repair it myself.
  • broadest Jun 17, 2009
    I live in Thetford which is near Norwich and Bury St Edmunds.
  • 4,234 Answers
I'm not sure which entry will get to you, so... The likely defective part is the voltage regulator. This should be fixble by any shop that handles audio gear. No special test equipment or parts are required. The regulator circuit should be fairly standard and simple. Where are you located so I can recommend a shop? Dan
Posted on Jun 16, 2009
    Scholar:
  • 109 Answers
Go here: http://www.roland.co.uk/warranty.asp and call them for a local repair center. I don't think they will repair under warranty (if its still under warranty) due to the damage being your fault, but they should direct you to a repair center.
Posted on Jun 20, 2009
2 Suggested Answers
  • 9 Answers
SOURCE: Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Hi I have a boss 1600br that will not power up. screen just blinks.I've .The br 600 model has trouble with a po wer diode causing it not to switch on. Could this also be the same with a br 1600?
Make sure you're using the correct power adapter or that the one you have is not malfunctioning. I've experienced Roland/Boss equipment blinking (and restarting over and over) when they are not receiving enough power. Sometimes even the resistance caused by too long of an extension cord can cause this to happen.
Jul 04, 2017 | Boss Music
Dont work display and no sound boss me-5
You have described a power problem. the unit is not coming on.Are you using the proper PSA adapter on this thing? If using a generic one, make sure the polarity is correct. Most of these things are wired backwards as compared to other types of devices. Does it work with batteries? This is where to start on a diagnosis. If it does, the wires from the batteries go through the socket where the adapter plugs in. Try spraying contact cleaner into the socket in case it is dirty or stuck in an open position. One more thing, IF a generic adapter was plugged into it that was opposite polarity, it may have burnt a diode on the circuit board. (a microscopic one at that)
Mar 31, 2013 | Music
How to ready the cd to burn music from br1180
They have some updates, if you have not run the update, that may solve the issue.
http://www.boss.info/global/support/downloads_updates/
http://www.bosscorp.co.jp/en/index.html
Apr 01, 2012 | Music
I recently bought a Korg Pitchblack Tuner. It tunes correctly, (maybe a little slower than my Boss) but it will not power other pedals with the daisy chain. I am using a standard Boss wall wart which...
The tuner uses around 500 ma which may be nearly all your wall wart can put out... DO NOT overload the power adapter by daisy chaining other pedal power loads on it.
Feb 08, 2011 | Korg pitchblack + Tuner
I just got a new Boss Metal Zone MT-2 pedal 3 days ago(1-28-11) n when I press on it is not turning on???
Try the obvious stuff first.
  1. Check that it has a battery in it and it is installed the right way round.
  2. Only use top quality batteries (Duracell Ultra or equivalent) do not use re-chargeables as they don't achieve adequate voltage.
  3. If you are using a mains adapter try a battery instead as the adapter may be faulty (or vice versa)
  4. Some effects pedals will not switch on without a jack plug in either the input or output socket (or both)
  5. If none of that works it is probably faulty - take it back to the shop and ask them to replace it or prove it works
Jan 30, 2011 | Boss Mt 2 Metal Zone Effects Pedal
My Boss RC-50 has stopped working. I used the power chord for my RC 50 in my Boss OC 3 pedal and then tried using the chord in my RC 50 again and it won't work. It won't even work with other power...
CHeck the voltage out of the adapter. It should be around 9 to 11 volts. If it is not, it is possible that the OC3 has reversed polarity AND a protector that put a short on an incorrect supply. If so, it could have damaged the RC50 adapter. If the RC50 adapter is putting out correct voltage, then I suspect the inout connector on the RC50 may be damaged or not quite seated. Visually inspect the connector first.
Dec 04, 2010 | Boss Rc 50
My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Apr 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
C.d burner has stopped working on my BR1180
As long as it indicates program content in the memory and can play the audio through an am p or headphones you should still be able to record the content onto your computer and burn it from there if your computer has a burner. I use Audacity which is a good freeware program.
Jul 14, 2009 | Boss Micro BR Digital Recorder
Jun 16, 2009 | Boss Micro BR Digital Recorder
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
788 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
Robert Graf
Are you a Boss Music Expert? Answer questions, earn points and help others
