Question about Cuisinart DCC-1200 Coffee Maker
The coffee maker shuts off before brewing the whole pot.
I love my coffee maker but it takes 3-4 times before it will brew the whole pot. I tried cleaning it last night and still the same problem
  • 85 Answers
Hello cjejmarsh,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Our coffee maker is only brewing half of the amount of coffee it should. Half way through the brewing, it shuts off. We've cleaned it with vinegar, but it still happens intermittently. It's actually...
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Dec 13, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Keeps shutting off after one cups is brewed even if filled for 10 cups
Hi, this is a common problem with Hamilton Beach on several models. There are also a host of other problems with them. There is no fix for these coffee makers. They are "throw aways" have owned them myself in the past and understand your problem. Sorry to sound so negative but Many people are disappointed with Hamilton Beach.
Good Luck.
Aug 17, 2009 | Hamilton Beach BrewStation 47214 Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Jan 12, 2009 | GE 106591 Coffee Maker
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Product is not completely brewing all of the water - it takes 3 times to brew a full pot of coffee. very frustrating.
Having the same problem. It's a thermostat issue. The product seems to have three. Trying to figure out which one is causing the problem.
Aug 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
213 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
