Question about Konica Minolta magicolor 2400 Laser Printer
Trying to print 8x11 borderless on Konica Minolta 2400W
Help! I purchased this printer for it's high resolution. I needed it for a book printing that I was doing. I cannot get my pages to print without a border. I have tried EVERYTHING.
I have set the settings all different ways...shrink to fit, fit to printable area. I have scaled up. I have done everything that I know to do. My pages cannot have this margin around them.
Anyone have any suggestions? (please!)
-Crystal
  • 909 Answers
Http://www2.konicaminolta.co.uk/more-information/support.html
Try this link for assistance
Posted on Jun 23, 2009
How do i change an ink cartrige in a canon 160 printe
The Canon Pixma inkjet printer is an all-in-one printer, scanner and copier capable of printing high-resolution photos. One handy feature is a slot for a memory card so you print photographs directly from your camera. It can also print completely without any border for full-sheet photos. Printing photos and other high-fidelity documents uses up ink more quickly, and you will probably need to replace at least one of your cartridges every three to six months, a process that should take you about three to five minutes.
1.urn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
2.Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
3.Pull out the used ink cartridge by pulling straight up from the print head, and dispose of them safely and carefully by putting them in a sealed bag.
4.Remove gently any packaging from the new ink, after giving it a few shakes. Pull off the protective tab on the cartridge, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
5.Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
Sep 06, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
I have a HP 1610 all in one printer. It is going through black ink cartridges very quickly (94 HP ink cartridge purchased from amazon, 1 a month or about 100 pages). I do not print everyday and very...
If you are buying genuine cartridges, check the print settings, you may have it set to high resolution and for the wrong media type.
Genuine HP cartridges are fully filled, compatibles sometimes are not. 100 pages of plain text is ludicrous. I would refer this to Amazon and ask for a refund.
The only other problem may be with a leaking seal, but i would have thought that this would be apparent by now, as ink would have leaked visibly
Mar 29, 2011 | HP PSC 1610 All-In-One InkJet Printer
In any mode he is printing to slow. 2 pages per a min. Its lexmark 650n
If the printer resolution is set very high, this can slow printing. So can high resolution input. Is the printer showing any sign of memory loss? Try a test print--it should come out quickly. Good luck!
Sep 18, 2010 | Lexmark T650n Laser Printer
My hp printer takes avery long time in printing pages than before
Check that you haven't increased the printing resolution beyond what is sufficient to print your document.
High resolution vs. draft output will cause you to use a lot more ink and will take at least twice as long to print a page because it is likely printing each line at least twice. This is how full color (photo quality) images are printed. If you don't need a photo to be dark, then set your printer to "Standard" or "Draft" settings.
Jul 12, 2009 | HP Officejet 4110 All-In-One InkJet...
Special paper printing
Does it act like it is printing or slide through very fast?Will it print on regular paper?
If so:
Make it a high resolution paper of same size.Do not make it a window decal.
If the paper is of heavy weight you may have to activate the envelope mechanism.
Jul 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
The printer prints very slowly all of a sudden. It took over an hour to print out 4 pages. I've unplugged everything. I've cleared the print ques. Same thing is happening when I copy. Help!
If the output quality has improved greatly, you may have selected the "High" quality instead of "Normal". The front panel should give you a clue as to how to adjust.
Jun 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
Trouble printing book made in Word 2007 using a HP psc 1315 print
Select the Page Layout tab, in the page setup group, select margins, The at the bottom, select custom margins. on the margins tab about 1/2 way down, select the down arrow next to Multipl epages and select 2 pages per sheet. Print a couple test pages and see if that is the setup you need.
Apr 06, 2009 | Microsoft Word 2007 for PC
All of my text is not printing.
Considering that the problem lessens further down the page, you most likely have a printhead that may be leaking (oozing) ink.
Once the surplus is wiped off on your paper, the ink flow is OK and the leak too slow to continue making the unwanted lines..
Try printing blank documents, you will probably see the lines with or without text printing.
I'm not certain how the printhead can be removed for inspection on that machine but it may need replacement.
Apr 28, 2008 | Lexmark X125 All-In-One InkJet Printer
HP PSC1350 All-In-One Printer
This printer prints at a really slow 1.4 PPM, and if it's doing that, it means that the buffer in the printer is full and it must print what it has in memory before recieving more of the page, if it's a really high resolution picture, it can take forever to print. This isn't a defect at all, it's just something that you can't fix that makes this printer useless for an office. I have this printer too, I usually just go do something while it does its thing...
Aug 14, 2007 | HP PSC 1350 All-In-One Thermal Printer
Konica Minolta magicolor 2400 Laser Printer Logo
709 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
