Question about Refrigerators
Does a hotpoint refrigerator ice maker have a inline filter that can be changed. the model number is csx22grxa-aa
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
MgcMn69
SOURCE: ICE MAKER NOT WORKING
Filters are a main problem with any kind of ice makers big or small...if filter is plugged up. Water can not reach ice maker and this will be main problem especially if you live in a high mineral deposit area. Change it if its been awhile (live since you moved in).
Posted on Dec 13, 2007
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
mikedurland
  • 481 Answers
SOURCE: I have a GE Profile
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 01, 2008
EllaWatson25
  • 725 Answers
SOURCE: I have a hotpoint refrigerator with model number: HSS25GFTA BB
You have a defrost problem. No biggie. Check your heaters first, then your t-stat and timer. After a year, you may need to repalce all three parts as after time, the ice takes out other parts if they are not changed right away. You will need to make sure the unit is completely thawed out before replacing parts for optimum use. Call or email us for the part that you need and we'll be sure to get them to you right away! Hope this solves all your problems.
Posted on Sep 09, 2009
Testimonial: "THANKS"
Samsung Model RF28K9070SR/AA water dispenser not working, water line & filter OK
while pushing button see if voltage to water solenoid if ok bad solenoid if no voltage check switch
Jun 11, 2018 | Samsung Refrigerators
Cannot find the filter on the whirlpool ED2CHQXKB05. The ice maker is producing ice with a white film on it. I was told to change the filter only I cannot locate a filter.
From what I can see with your model number you do not have a water filter contained within the cabinet. You can install an inline water filer between the source and the refrigerator. Also, you will likely have hard water stains in the ice maker mold itself, FYI.
Oct 01, 2010 | Refrigerators
Hooked the water up to the ice maker and the water keeps puring out.. what do we do?
Where is it pouring out? Can you tell?
Here are some common problems:
1- Filter not installed or not tight
2- Loose fitting or cracked water line
3- stuck valve on ice maker
rlet me know where it's leaking..and a make and model number and I can help more.
Sep 06, 2010 | Hotpoint Refrigerators
Bad ice from ice maker
im going to assume u got a inline water filtr fo ur ice msker. u mite want to change it out, if its worn the seals may allow the filtering materal to release, ie. black charcoal may be releasing inro ur water lines . replace filter, cycle ice for 24hrs, to get rid of bkaxck particals in line, dispose of ice, u should ok after that
May 21, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice maker do not work water do not enter tray
does the rifrigerator have an inline filter. or did you change the filter. if so the filter only feeds one way. also the water solenoid maybe bad that feeds the water into the refrigerator
Aug 05, 2009 | Refrigerators
Musty smell/taste from water dispenser in refridgerator
The icemaker has mold or mildew in the little nooks and crannies. An appliance parts supplier might have something available for flushing but I am not sure. There might be something in the ice bin or on the auger contaminating the ice and water as well. Check back to the source as the water supply filter may have accumulated something unpleasant while the ice maker was down. Hope this input helps.
Dec 30, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Ice maker in the door does not switch back to cubed ice
spring on bottom of ice tray has possibly come out of place, mine did, putting the spring back in place did the trick.
Apr 16, 2009 | Hotpoint HSS25GFP Side by Side...
Ice from ice maker taste bad and can not find a water filter on it.
I would install a filter inline on the water filter I have one under the sink and on the ice maker
Apr 14, 2009 | Refrigerators
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
