Question about Car Audio & Video
How to ajust amplifiers (car audio)
To whom it may concern please help.
How do i go about to adjust my cars amplifiers and midrange crossovers.I have installed to Star sound 4 channel amps.Please can u help how must i adjust level,bass boost,lpf,x-over,lpf,subsonic,bass boost frequincy(12db 6db 0db) ect.
If you can help it would be most appreciated.
Thanks Barney Nel Westrand.
  • Caleb Judd May 11, 2010
    Need more info on how this system is set up. which speakers/subs are connected to what etc.
  • 58 Answers
MOST OF THE TIME U WANT UR AMP RUNNING UR SUBS TO MAKE THE SUBS SOUND REALLY DEEP AND HITE REALLY HARD BUT BE CARFULL WITH THE BASS BOOST IT CAN BE TO HIGH AND CAN BLOW UR SUBS, NOW WITH UR AMP RUNNING UR MIDS U DONT WANT A LOT OF BASS MAYBE NOT AT ALL CAUSE UR SUBS WILL HANDLE THAT, SO U WANT A LOT OF TREBLE WHICH SHOULD BE THE LPF, O AND ANY WHERE FROM 6DB-12DB WILL BE GOOD.
Posted on Jun 18, 2009
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
Tri-mode amplifier hook-up
you dont have to have a crossover to hook up ur amp 2 ur subs
Feb 27, 2010 | Alpine MRP-F600 Car Audio Amplifier
I need installation manual
its not a subwoofer it is a midrange speaker. all you do is connect your outputs from the radio to the crossover then connect both the tweeter and midrange to the outputs on the crossover. it is called a component set.
Oct 01, 2009 | Quantum Audio QP500C Car Subwoofer
My ma audio hk 898 will power on but will not push subs at all what can i do
Hello 76firebirdfo,
If there's no sound at all from the subs and you know they are good, there's probably no output from the amp. It's either wired incorrectly or it is defective.
If there's some sound but just not loud enough, then either the amp is not getting enough of an input signal from your head unit, or the amp settings are not adjusted properly. Adjust the crossover and gains for the best output to subs. LP filter on, crossover frequency at about 80-100Hz, and gain to maximum without distortion when head unit volume is at about 3/4 maximum.
Hope this helps.
Jul 14, 2009 | MA Audio Hard Kore HK-898 Car Audio...
Crossover issues?
if only highs are comin through subwoofer then check pf switch on amp then adjust crossover frequency to 80hz hope this helps
Apr 28, 2009 | Infinity 475A Car Audio Amplifier
Deck speakers
An active crossover is needed if you plan to do a 2.1 or 4.1 or 5.1 setup.
Check if you have a subwoofer output from your head unit (most later models have). If there is, you might not need an active crossover anymore, but it depends on how you like the sound quality of the separations (low, mid, high). Please note the speaker polarities too.
Oct 16, 2008 | JBL GTO 301.1 Car Audio Amplifier
How to adjust
hello . i think i can help ...u want to set your crossover points to 125Hz and for the subs if u want deep bass set them to 50 to 80Hz...try them and see what u like best
Jun 20, 2008 | Sony XM-2200GTX Car Audio Amplifier
Crossover
i have lost my manual to the phoenix gold 600.1 xenon amp. i want to set it up by the book can you help me ?
Apr 25, 2008 | Phoenix Gold Xenon-600.1 Car Audio...
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
Car Audio & Video Logo
194 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
