Question about Wurlitzer CD Players
Cd selection rowe cd 100 power is ok but there are no 0's lit up in the "selections being made" area. there is a 0 in the "selections remaining" area. also in the service mode it says "errors exist" please advise. thanks ,jim
  • 1224 Answers
heres the manual link print out manual and save
from manual discription the feature your looking for is on the front deck single auto repeat, repeat, single
i hope this is what your looking for
Posted on May 08, 2008
  • 624 Answers
Yes, it is possible. The F61 error is a failure in the power supply or the amplifier. I repair these every day and it will require good soldering and troubleshooting skills to fix this yourself.
If you would like to try, let me know, and I will give you more information. But the best thing to do is take it to a service center and let a professional technician check it out for you.
Posted on Jul 01, 2008
SOURCE: Rowe cd jukebox
See your manual on how to enter SERVICE MODE. When you enter it the display will show SERVICE MODE. Then type, hold and push, or push the keyboard keys as follows:
Type 20 - display will show ATTRACT MODE ON
hold RESET key down and then push 9 key - display will show ATTRACT MODE OFF
push POPULAR key
The problem should be fixed and you can shut the door and resume normal operation.
Posted on Jan 15, 2009
Testimonial: "Thanks very much!!!!!"
SOURCE: Rowe AMI CD100 RAM Error
try this turn the box off , hold down the 0 and the 1 selection button
at the same time turn the box on. that reloads the prom to the ram
Posted on Aug 13, 2009
  • 567 Answers
SOURCE: nsm cd wont play
error 61 means exchange cd player or decoder board before that try another cd
Posted on May 10, 2010
  • 211 Answers
SOURCE: Can't play album
Set the switch on the computer...Service Switch ON. Press LT button on the computer. On the front keyboard press 4-R, 9-R, zero one. That is press4 hold it down and press R. Press 9 hold it down then press R. Enter 01 on the front keyboard. Set service switch to off. Press LT button. Job done.
Posted on Aug 31, 2012
0 characters
1 Points
How do I set free play on my rowe laser100
Hi you put on service , then you enter 84 then you put the number of credit you want by example 9999 and you press popular and you put back to normal mode
Jul 03, 2014 | Wurlitzer Jukebox CD Player
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
Can't play album
Apr 08, 2012 | Wurlitzer Jukebox 1015 One More Time...
Keypad on rowe r-89 will not register a selection
HellooCheck the carbon conductor tracks of that row. it may have a break anywhere. It is a repairable one, as carbon tracks can be drawn into, with a special type of pen and carbon ink. OK.
Dec 21, 2011 | CD Players
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Alan Hood
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Hi' I have just got a rowe ami r-83 disco jukebox. All is ffine apart from when you select say 120, it picks up and plays 168. Any ideas. Regards Chris
you need to check the Home signal to make sure the opto is activated at position 99. When the unit powers up the mechanism scans one complete cycle so it re-indexes the computer and starts scanning from position 00. If you want a quick test, turn the power off and scan the carousel to position 99 by releasing the latch on the left side of the mech just under and behind the mechanism motor. then power up the unit and it should pick the right selection. You can also observe the optic indicators on the mechanism control board under the turntable. The Home signal only operates at 99, the Index pulses between each record as it scans. Good Luck
Nov 29, 2010 | Wurlitzer Jukebox 1015 One More Time...
Cd holder spins round doesnt select cd
I can help with this problem, but I need more information. Does it just constantly rotate? Are the lights marked K and Z constantly lit on the Selection & Credit Computer? If so, it may be as simple as a burnt-out light gate bulb....I have these in stock and would be happy to help you troubleshoot further. Please email Rod Stebelton,
Nov 04, 2009 | Wurlitzer Jukebox 1015 One More Time...
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Alan Hood
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Alan Hood
May 30, 2008 | Wurlitzer Jukebox 1015 One More Time...
CD Players Logo
26 people viewed this question
Top Wurlitzer CD Players Experts
Dave Jukebox
Are you a Wurlitzer CD Player Expert? Answer questions, earn points and help others
