Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Poulan Pro 42". Won't start. Has another new battery.Have been jump starting & now that won't work.Smoke comes out of cylinder on right side of engine..smells really bad. (Engine struggles to even turn over) Cindy
  • cindyareese Jun 16, 2009
    Kevin, Did you get the f/u email? cindy
    Genius:
  • 1,847 Answers
Hi Cindy,
I will try to assist you with this. remove the spark plug and ground the plug out on some bare metal. then crank the engine over and see if there is spark. if there is then ( and I suspect that there is) you will need to disassemble the carb. remove and clean the jets in the carb look at the main jet and make sure that the cross passages are clear also. once the carb is clean reinstall itand it should run fine at that point.
Kindly rate the answer
Thanks
Kevin
Posted on Jun 16, 2009
  • Legin Varghese
    Legin Varghese Jun 16, 2009
    Which email are you talking about?
    Thanks
    Kevin
New 42" poulan pro smokes when started
All two strokes smoke when they start up. Shows you are getting lubrication. 4 strokes smoke a bit, especially if the crankcase is over filled.
Feb 14, 2016 | Poulan Garden
I over heated,the serpentine belt snapped. Opened the hood to find steam rapidly coming out of both the antifreeze and out of the engine right by the head gasket. It wasn't smoke not blue or black jus
Perform a compression test on your cylinders. One unfortunate result of overheating is the blown head gasket. Without compression your motor will not run. Tester are not super expensive or some stores will lend tools.
Jul 09, 2013 | Cars & Trucks
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I bought a new mower this summer. was stalling out and now won't start at all. where is the air filter located
The air filter is located on the right side, opposite side of the muffler. It is behind the flat vertical cover on the right side toward the forward end of the engine. The cover has a curve on the left and right side of the cover.
Aug 02, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I have a brand new battery in my Poulan garden tractor. When trying to start, the flywheel will go around slowly and try to start but won't fully crank. When I put a battery charger on the battery it...
Bad battery, I know that you said that you have a new battery, try to borrow one from a neighbor and test it. Yours could be insufficient in cranking amps or your battery is bad. I have had a battery that would show the proper voltage, but as it had aged the cranking amps had fallen off and it could not do it anymore. This condition is not so common as a bad cell, but it does happen, it did to me.
I hope this helps.
Jul 22, 2011 | Poulan Pro Garden Tractor 2005 and Older...
Poulan Pro PP165H42A. Was running OK. Started coughing and died. Got it to start and got back to the garage with it poping and sputtering. Assumed low on gas. Some gas remained (1 1/2 inch)while I...
Sounds like the starter solenoid which is basically on the side of the tractor below the key inside the side panel. Part number 146154 and you can get it from Searspartsdirect.com or Jackssmallengine.com . Easy fix just pull the negative battery cable off the battery first so you don't get sparks flying! Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My sister bought a Pro 550. Got a good deal but there was no manual with it. Brand new from Walmart. Was working fine. used it twice. No problems. Boyfriend came by. Said she was suppose to put the whole...
Option #1:If its less than 90 days old return it to walmart.
Option #2: drain the oil and refill with the correct amount. Contact Puolan or a poulan dealer for a manual.
locate the model number and look for your manual here
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/961240002.html
Eric
Jan 19, 2010 | Poulan Pro " Pro" Self Propelled Mower
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
