Question about Boss Audio Players & Recorders
Boss br1180 burnt inside, who do I go to for repair?
I stupidly used my laptop charger to turn on my Boss br1180 and it burnt something inside. When using the correct mains adapter the screen flashes on then off after a sceond I just need to know who i can send it to for repair at a fair price. Or what I would need to do to repair it myself.
  • Jim Dyck
    Jim Dyck Jun 12, 2015
    did the same thing today with the same result. Email me if you managed to get it fixed. gymdyck@gmail.com thanks.
  • 4,234 Answers
The likely defective part is the voltage regulator. This should be fixble by any shop that handles audio gear. No special test equipment or parts are required. The regulator circuit should be fairly standard and simple. Where are you located so I can recommend a shop? Dan
Posted on Jun 16, 2009
Motherboard charging chip burnt
You cannot jump over a failed component. You will have to replace the chip and some other failed components that feed the chip. There is no other solution to repair the charging circuit.
Oct 12, 2017 | The Computers & Internet
Toshiba satellite won't turn on
Before you make a decision about the next step, maybe you would like to know why the laptop charger is not working. Here are some commonly found reasons for this problem.
You have been using the wrong laptop charger for your machine, or someone else has been using your laptop charger for another machine. This may seem like a harmless act, but it affects the battery on your laptop, and charger you are using as well.
Your laptop battery has become weak and worn out from excessive use. Due to this the battery is not charging at all (or charging very slowly) when you plug in the charger. In this case there is absolutely nothing wrong with the charger itself.
The wire of the laptop charger has got a distinct curve at one point, and this is restricting it from transmitting power. You need to look out for such bends in the wire, as this will ruin the efficiency of the charger in no time.
This may sound elemental and stupid to some, but it does happen to many people. Maybe you are simply using the wrong laptop charger by mistake, or maybe you have failed to switch on the power switch. Check both these things to be sure.
Any of these potential causes could be the reason behind your laptop charger not working. As a result of these, either the mains power lead of your charger may be damaged, or the power supply unit may be damaged, or maybe the lead itself is damaged or broken somewhere, or some circuitry inside the laptop is damaged, and not responding to the charger. It's hard to accurately tell which of these problems could be the real cause of your laptop battery not charging, without physically examining the machine.
Solutions and Answers
Now if you are well versed in computer hardware you can attempt to fix this yourself. Most people cannot do this, and it is advisable for them to visit a computer repair shop instead. They will examine the laptop charger not working problem, and suggest some suitable remedies for it. Depending on your budget, you can choose an option that suits you and simultaneously solves your problem. Here are some recommended solutions.
Buy a brand new charger which will definitely solve your problem of charging the laptop for a long time.
Replacement Toshiba Satellite M305 AC Adapter 75Watt 19V 3.95A
If you're hesitant to pay that amount, you can try and purchase a second hand laptop charger from eBay.
Get your's repaired and pay the repair shop the fees that they charge.
If your warranty is still valid, you can simply get the laptop charger replaced.
Reference: http://www.buzzle.com/articles/laptop-charger-not-working.html
Oct 27, 2012 | Toshiba Satellite M305D Notebook
How to ready the cd to burn music from br1180
They have some updates, if you have not run the update, that may solve the issue.
http://www.boss.info/global/support/downloads_updates/
http://www.bosscorp.co.jp/en/index.html
Apr 01, 2012 | Music
C.d burner has stopped working on my BR1180
As long as it indicates program content in the memory and can play the audio through an am p or headphones you should still be able to record the content onto your computer and burn it from there if your computer has a burner. I use Audacity which is a good freeware program.
Jul 14, 2009 | Boss Micro BR Digital Recorder
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
Burnt out my boss BR 1180. How do I repair?
I'm not sure which entry will get to you, so... The likely defective part is the voltage regulator. This should be fixble by any shop that handles audio gear. No special test equipment or parts are required. The regulator circuit should be fairly standard and simple. Where are you located so I can recommend a shop? Dan
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Set up m-audio buddy dual mic preamp
ive got a problem cuz this thing doesnt have a ******* firewire port. and i was hopoing to use this for pro tools. i need to know where i can get an adapter of some sorts. but what you should do is hook the mics in to the back ports. adjust volume. then do the ****
Mar 25, 2008 | M-Audio Audio Buddy Dual Mic Preamp...
287 people viewed this question
Top Boss Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Boss Audio Player and Recorder Expert? Answer questions, earn points and help others
