Question about Aiwa Audio Players & Recorders
Cd tray opens/closes by itself, intermittant full volume at start
I was given this stereo( i am the local tinkerer ), it kicks but when it plays!! my friends son forced the cd tray back in and it ''jams up and opens and closes randomly when you turn it on or off'' also, sometimes when you turn it on, the volume is at full blast!! and you cant turn it down!! it is a beautiful stereo, never has a spec of dust on it, i would like to try to save it!! my friend must have tried to open it up, because there are a couple screws missing from the cover. any help/advice would be greatly appreciated!
  • twohandy4u2 Jun 16, 2009
    it is an aiwa cxnd7 thanks, i thought i had it posted in the previous post
  • 4,234 Answers
I have a few ideas, but the model number is required for me to provide details. Can you please update this with the model number? Thanks, Dan
Posted on Jun 16, 2009
  • ABRsvcs Jun 16, 2009
    There are 2 problems with this unit:
    1) The CD tray assembly is "out of timing". The gears need to be realigned to get the proper timing. I'mnot sure I can describe how to do this as it takes a little practice.
    2) Check the 5V supply area for bad solder connections. While it is possible that the electronic volume control IC is defective, it ismore likely that it is getting confused due to a low 5V supply.
    Check that first and let me know what happens. It is also possible that the position sensors for the try are causing the controller to mis-interpret the signals again due to the low 5V supply.
    Please keep me posted.
    Dan
I have a rca rs 2663 stereo, The cd tray will not open or play cd's anymore. Could you please help
It two things can cause this:-
The motor is damaged ( you can listed closely to hear if the door motor runs when you try to open the tray.
Or The belt that takes power from motor to open mechanism is damaged.
Aug 19, 2011 | RCA RS2663 Shelf System
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
I would like to know more about my factory stereo. dont have a users manual, and the screen shows a cd. when the aux is pushed it shows cd 1 track 1 and starts to play with no sound. i cant find the...
The "SCV" you see on the knob outside of the volume is Speed Compensating Volume. basically it automatically turns up the volume as you speed up and the vehicle makes more noise. given the fact that you don't have an owners manual i would recomend visiting http://gmownercenter.yahoo.com. you will need to register with a yahoo id but the site is full of information including an owners manual that you can download on your computer. hope this is helpful for you!
Sep 30, 2010 | 2001 GMC Jimmy
It keeps saying open tray close tray
If the fan revs up to full speed in a few
min you got thermal prob ,
or could be lose connector on the
cd drive , but thats rare. I have seen
that only once and ihave fix 100,s
Jul 01, 2009 | Microsoft Xbox 360 Console
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Cd error message
Try to disconnect battery contacts and connect it back. Check also if there is an emergency opening device. In some model you have a pin hole underneath the cd tray. push a staple tip inside the hole, and this will release the cd.
If the tray still does not open, you may need to have a repairman opening your stereo at your local service point.
Regards
Apr 03, 2008 | Car Audio & Video
Drawer closes by itself
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Mar 28, 2008 | Pioneer HTD-520DV System
Tray opens / closes on its own and will not play
Your open/close button might be stuck, you can try and unplug it and spray it with silicone lubricant and push it over and over again for a couple of minutes and then turning it back on after about 30minutes so the lubricant dries down first.
If all else fails, have a local appliance technician take a look at it...
Dec 09, 2007 | Hitachi DV-P323U DVD Player
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
472 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
