Question about SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG)
Mtu setting its telling me that my mtu setting should me higher or at 1364
    Sergeant:
  • 322 Answers
Configure it, then change it to 1500. Or you can also change put it to its default.
Posted on Jun 16, 2009
My xbox is telling me my network doesnt have a sufficient mtu setting and i needto go to my router configuration webpage and set the mtu to auto or 1364 or higher. i have no clue what im doing
Most routers reside at the following IP address: 192.168.1.1
Go to your computer (hooked up to your network) and type that address into your URL field in your browser. Default passwords for almost all routers is as follows:
USERNAME: admin
PASSWORD: admin
Once there browse through the options and settings tabs. Change NOTHING YET. You want to look for an option called MTU. You will probably find it in a 'Settings' Tab or 'WAN' tab. Most routers should have this set to AUTO as default. Once you find it, ensure this is set to auto. Save changes and turn your router off and back on.
Turn the xbox off and back on as well and see if this resolves your issue. If your router was already set to auto for the MTU setting and you are still having issues, go back into your router and access the section where you found the MTU settings. This time set to 1364 instead of AUTO and save changes.
Repeat the off/on process on the router and xbox and see if this fixes your issue.
Sep 13, 2011 | Blitzz Technology BWA711 Router...
Cant connect to xbox live due to low mtu
Mine has been doing that lately too. Log into your router or what ever supplies internet to your xbox. Make sure the MTU is 1364 or higher. My router is set up to that and it still does that and doesn't work until the next day after about 12 hours I would guess. The xbox tells you what to do also.
Dec 17, 2010 | Microsoft Xbox 360 Console
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
MTU settings
So your first problem is to learn how to login to your router. Please see your documentation. You can usually find the documentation for any router/homegateway at the vendors website.
If you still can't logon you may have to do a "hard reset" of the router/gateway to force it back to the default logon/password.
Now having solved that you need to understand that the largest MTU setting that you can use to increase your internet performance must be equal to or smaller than the smallest MTU setting between you and your internet target. If you make the MTU larger than that it will slow down your connection because it will now have to use 2 frames transmit and recieve what it used to only use one for.
While there are tools that can help you with that, the simplest solution is to find out what your ISP says the MTU should be.
Tom
Aug 21, 2009 | Toshiba WRC-1000 Router (PA3227C1ETC)
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My x box keeps saying my mtu settings need set at 1364 or higher i have a motorola sbg 900
Is this a router or a modem? Could you please tell me exactly how your xbox connects to your network?
Jul 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I need help changing the MTU settings on a D-link DI-624 router.
you have to enable wi fi in your router for that you need to access it.
Coonect your router to 1 computer with ethernet cable then access following link
http://192.168.0.1
or
http://192.168.1.1
then type username as "admin" and password as "admin" or blank or "password"
Then go to wirelesss and enable wi fi .
Jun 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Mtu 1364 error
where do you get the mtu error??on xbox or on the router??
Apr 06, 2009 | NetGear WGR614 Router
SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG) Logo
214 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
