Question about HP LaserJet 1200 Printer
My HP Laserjet 1200 is screeching constantly
My HP Laserjet 1200 is making a terrible and constant screeching noise. It makes the noise with or without a cartridge. Seems to be coming from the left-hand-side. I cannot recall if this began with a paper jam, but nothing seems to be lodged in the rollers.  It started suddenly; I never had any trouble with the printer prior to this.
Probably the laser-mirror motor. It will screech until the load gives a error and the printer shows error/ is dead.
However, the motor can be lubed. Remove sides, remove screws found, remove top cover. Remove and open the black box containing laser. Remove motor board and lube the motor, dont get the mirror dirty. Asseble. Total time 15min...
Posted on Sep 09, 2009
  • 1 more comment
  • kaslan13 Jun 05, 2011
    just wanted to say that this solution worked! lubing the motor is probably the hardest part. after you remove the motor board (3 black screws, 4 purple power wires, and 1 ribbon cable), you need to disassemble the motor itself for proper lubrication.
    1) carefully remove the clip (looks like an omega symbol) on the spindle
    2) once clip is removed, square mirror can be lifted off spindle (don't lose the gold washer! and of course, don't get the mirror dirty)
    3) remove motor housing, and spindle can now be properly lubed. (we used bike lube but wd40 should be fine).
    4) put everything back in reverse order and you're done!
  • sabrina cook Sep 04, 2012
    How do you remove the clip? it's impossible
  • Edward Ruschmann May 13, 2013
    Indeed, removing the clip is one way but not necessarily the only way to access the motor shaft. Next to the round motor, there is a white pin/ post/ retainer. From the BOTTOM of the circuit board, gently nudge aside the white (Teflon) post, and only enough to clear the edge of the motor. Now, motor housing will lift off allowing access to shaft and bearing surfaces. Good ol' 3 in 1 Oil did the job for mine.
    President:
  • HP Master
  • 1,996 Answers
Possible help from the HP forums here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 16, 2009
I have a HP 6MP printer and it is now constantly jamming the paper and making harsh roller noises?
Can't be positive without hearing and seeing myself but the main motor makes a terrible sound whrn the gear on it cracks or it locks up. The jamming could also be because a piece of paper is jammed under the paper guide directly underneath the toner cartridge. If you look down in the machine you will see one silver screw on the left side, that is all you need to remove to take out the guide.
Aug 20, 2010 | HP LaserJet 6mp Printer
Hp p2015 laserjet makes constant buzz sound
this sounds like a possible fan issue, check the vents to pinpoint the noise and then replace the fan that you hear the noise coming from... if you need to order the fan, just let me know and I'll find it for you . hope this helps, if so please mark Fixa!!
Jul 18, 2010 | HP LaserJet P2015dn Printer
My HP laserjet 1200 is making a terrible noise when printing - do you have to oil the rollers?
No Please don't oil any part of the printer, oiling may damage the complete printer first check if the nopise is coming from rear, Top, Front or side.
If noise is coming from Top than possibly top outbin roller are making noise.
If side tham may be toner cartridge or cartridge motor is making.
If noise is coming from rear than either fuser or the gear which rotates the fuser are making noise.
If noise is coming from from than Tray 2 pickup assembly or faulty tray is making noise possibly faulty registration assembly can also mak noise none of the part should be oiled only the faulty part should be replaced.
May 11, 2009 | HP LaserJet 1200 Printer
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
Hp 1200 laserjet printer generates a lot of noise from the laser cartridge
I would leave the printer off and contact your printer's technical support department and let them know and they are the professionals specifically for that and they would be able to give you an answer and provide you with choices to fix the problem!
Oct 26, 2008 | HP LaserJet 1200 Printer
HP Laser Jet 3300 constant noise
I had the same problem. After updating a hp firmware, so far so good. The noise is gone.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=66367&prodTypeId=18972&prodSeriesId
=66359&swLang=8&taskId=135&swEnvOID=54
That is the link for the 3330. It is under the downloads section and is at the bottom. They refer to it as firmware
Nov 08, 2007 | HP LaserJet 3300 All-In-One Printer
HP LaserJet 1200 Printer Logo
1,817 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
