Question about Brother HL 1430 Laser Printer
Address label is around drum. How do I clear it
Address label is around drum. can I get into the drum by removing the bottom panel? If not how do I get at the drum to clear it? Tried sending a sheet through to clear it and the whole lot is now around the drum with barely a bit of paer showing to grab
There is a problem as it takes awhile to get into it and I did not have the time. I will never put address labels through a machine of mine again when it only coast $4.60 for a commercial stationary warehouse to do it. I should have kept the labels in the hotwater cuboard as I think they were a little damp. Bought another printer as my drum was getting to the end of its life anyway and the start labour cost for a outside repair was $130 and a new Brother HL 2140 was $169.00.
Thanks for your offer of help it will be interesting to see how long it takes to remove the jam up.
See ya
Jim
Posted on Jun 17, 2009
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
The drum on my frigidaire Gallery dryer is tipped down , so there is a gap at the bottom and clothes get stuck in it. Can this be adjusted?
Suspect one or more failures of the drum front support bearings. Remove the cabinet top by removing several screws at the rear of the top, then pushing it to the rear somewhat which should allow the top front to lift up to allow removal of the front cabinet panel by taking out several screws on each side, then lifting the panel up to release it from the bottom. Once the panel is off, the support bearings should be mounted around the drum opening in the panel. Hope this helps!
Nov 20, 2010 | Frigidaire GLER341A Electric Dryer
Need steps to change belt on drum of a fisher and paykel dryer
i changed one on a ge unplug electric first or turn off power. I took off my front door 4 screws held the top down look at the top edge where the door closes. this allowed the top to hinge back and you can see the belt and drum . there should be a few screws that hold on the front face lean forward this should separate the front of unit if wires label and remove make sure to put back in same place you can also take picture with camera to really remember you should have some sort of access panel at bottom of dryer remove and look in see if you see the motor with a pulley and the tension device mine pushes up to release tension once all free from pulleys take drum out from front end place belt around drum and stick back in put the belts around the pulleys now replace the front put in screws and spin drum by hand to see if aligned back up an finish up
Jan 26, 2010 | Fisher and Paykel Dryers
How to put a belt on a Maytag DE 410 dryer
with some you have to remove the front upper and bottom panel
then lift drum off bogie wheels and move it ahead a few inches then loop it over the drum and around the belt tensioner pulley most swing up and down so thatyou can put belt on
Dec 18, 2009 | Dryers
I do not know how to change belt
This can vary from dryer to dryer, but most are basic, with slight variations of this set-up. The belt goes around the drum and around a pulley on the motor shaft. It then routes thru a tensioning device, usually between the motor pulley and the drum on the bottom. The drum is held in place front and rear by the cabinet itself. You will have to remove the front panel to get the belt around the drum. In order to remove the front panel (door panel) you will have to detach the top. It is usually held in place by a couple of screws in the rear, then you can bump it forward and pull up. You will then notice how the front is attached. Be careful to replace the drum (exactly) as it is or it will not turn properly.
Jun 20, 2009 | Dryers
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
BELT REPLACEMENT
Take off the front kick plate (bottom panel) then remove the front panel. The top panel will be attached to the front panel by some plastic push in retainers you can loosen with a screwdriver. The belt will go around the drum on top to a drive wheel at the bottom of the machine. you will have to slip the belt around the drum in the front or back of the drum to get it around it.
Jul 04, 2008 | Dryers
Danby dcd5505 dryer
remove the front panel(s) and the top panel. the belt will go around the drum to a drive wheel at the bottom. the belt turns the drum. You will have to route the belt around the drum and go either in front of or behind the drum to get the belt installed correctly.
Jul 03, 2008 | Dryers
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Brother HL 1430 Laser Printer Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
