Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Indicators/flashers left hand indicators stay on when selected and dont flash.right side works fine,plus all operate properly when the hazard function is selected.
  • 27 Answers
Check your wiring for continuity. Mine did the same on the Fatboy - found a broken return wire by the right Handlebar switch when I opened up the switch gear housing on the bars. Bit of solder, heatshrink and good as new! (my problem light was on the right side so check the left side on your first - was a white wire with orange stripe I think, should be easily visible from the indicator switch inside). All the other lights worked fine. Maybe an earthing problem?
Posted on May 24, 2008
My left turn signal started to only work about 50% of the time, it wont work hardly at all now. the right turn signal is fine. When I try to use the left turn signal, there is no dash indicator lights
Hey Bob how's it going ? I have been looking at Chevy service info for your vehicle and this a little on the complex side or that is the way it sounds from the turn signal description !
Turn Signal Lamps
The smart flasher (GMSF) is an automotive flasher designed to accept turn, hazard, and brake inputs. The GMSF will provide corresponding outputs to the exterior lamps and instrument panel turn signal indicator lamps. This lighting system has dedicated lamps for the turn/hazard functions and dedicated lamps for the brake function. The system incorporates the use of flash rates for diagnostics. The flash rate is a calculation of the number of flashes that occur within a 60 second period. This system uses a percentage of on-time to off-time called duty cycle. For the bulb outage condition, the indicator of the vehicle side on which the outage occurs shall assume bulb outage flash rate mode. The opposite side indicator will assume the normal flash rate mode for an input from the non bulb outage side of the vehicle. Hazard warning lamp outage will maintain a normal flash rate as long as 2 or more exterior signaling lamps are functional. During all modes of operation, the IPC will receive the same flash rates and duty cycles that the exterior lamps receive. The IPC will then control the indicators in the cluster. The vehicle operator will be provided with an audible and visual indication of the flasher operation. Below is a table with flash rates and duty cycles:
Are all your bulbs good ?
Operating Condition
Flash Rate
Duty Cycle
75 to 105 flashes per minute
45% to 55%
Turn Signal Lamp Outage
2 or 3 times faster than normal flash rate
35% to 55%
Feb 02, 2015 | 2005 Chevrolet TrailBlazer
When I turn on either left or right indicator both indicators light up
try pushing the hazard light switch again. what you have is the hazard lights in operation ( both sides indicators working) In normal indicator operation power from the flasher unit is directed to which ever side you select but by pressing the hazard light switch the indicator power lights up all lights.
Nov 13, 2014 | 1987 Citroen AX
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
Oct 13, 2014 | 2013 Nissan Rogue
Right turn indicator stays on
flasher relay under steering column does not work,switched it with hazard and see if it works,then get the new one,make sure the light on turn signal in front or back is not burned out first
Apr 04, 2014 | 1992 Chevrolet Lumina
I have an 02 kia sportage. my signal lights come on but dont blink outside. no lights for the signal lights come on on the dash at all. also, no hazard lights.
If the 15A HAZARD fuse in the passenger compartment fuse box is OK, power is getting to the hazard function of the flasher unit. Pressing the hzard switch should cause the hazard lights to flash. HOWEVER, there is an electronic time and warning indication system module connected to to the hazard switch lead and that may be affecting things. If the 10A TURN fuse is OK, power is applied to the turn switch (with the engine in START or RUN) and you state you can select a right or left turn. HOWEVER, the RED/WHT and RED/BLU outputs from the flasher unit connect directly to the front and rear turn lamps and the instrument cluster turn indicators so you are not getting any flasher output. Again, that electronic time & warning indication system module could be affecting things
Oct 26, 2012 | Cars & Trucks
Left turn signal lights are not working
In my case the left front turn indicator lamp worked, but not the left rear indicator, although all the lamps would turn on with running lights activated, as well as the backup light and 'night-light' mode. The left rear turn indicator would not work with the hazard lights activated. I tested the combination switch (this is the left/right turn indicator switch you use when driving to indicate which direction you are going and is mounted/located on the steering column) and it tested O.K.. I had good continuity from the combination switch black wire, and resistance on the blue-white wire from there to the left rear turn indicator lamp, as well as good continuity on all wires going out from the left parking light fuse. Since the Haynes manual indicated that the flasher module was probably good if it made the tell-tale clicking sound, I was feeling perplexed. So I took it into a local shop that specialized in auto electrics and it turned out to be the flasher module. I was under the impression that it operated in a straight-forward left-right manner, but apparently it has a different circuit for each turn indicator lamp. So even if it is making the appropriate clicking sound when the combo switch is flipped, it could still be the flasher module. Obviously the manual leaves a bit to be desired in the troubleshooting of malfunctioning turn indicators.
Sep 07, 2012 | 1998 Dodge Caravan
My turn signals stopped working suddenly on my 1992 ford probe lx. Prior right side was blinking faster. Changed signal switch next to steering column changed turn sinal/hazzard flasher by the clutch...
If this is not working on the right side and is OK on the left side then one of the indicator lamps on the right side has blown out. The reduced load on the right hand indicators causes the flasher can to flash faster.
Try turning on the hazard switch then walk around your car to see which lamp has blown out.
Feb 24, 2012 | 1992 Ford Probe
I have a 1995 chevy cavalier and the turn signals just stay on and don't blink. I have changed the flasher and the multi function switch and still no luck
First, is it doing it on BOTH isdes or just on one side? Example: turn signnals flash OK when turning left, but only come on and stay on when turning right. If it is doing this, then you most likely have either a blown bulb or a bad bulb socket on the side that is not flashing. You need to check both the FRONT and REAR bulbs to make sure they are all functioning properly.
If it is doing it on BOTH sides, then you either have a bad flasher, or at least 2 bulbs burned out (one or more on each side).
Are you sure you replaced the correct flasher? The flasher for the HAZZARD lights is plugged into the convinience center under the left side of the dash. If this is the flasher you replaced, it is the wrong one.
The turn signal flasher is mounted to the driver's knee bolster bar near the steering column. It is held to the bar with a clip. (see diagram)
Sep 25, 2011 | 1995 Chevrolet Cavalier
Lands Phones Logo
202 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
