Hp designjet 500 (42'')
My hp designjet 500 (42'') is giving printouts without any error on front panel but while printing the cyan ink dribble on the whole printout. I have changed all print heads & cartridges but the cyan ink still leaking and spoiling my printouts. what should i do?
  • 255 Answers
1. remove your catridge
2. remove or change the foam which is located
at the bottom of catridge head
3. hope this will help you to solve your problem
thanks
Posted on Jun 16, 2009
Can it (HP deskjet F380 all in one) still print with only color cartridge or only black cartridge ? Or Should two cartridges remain together to print even one is empty ? Thanks
the answer to your question is yes,it can still print with only one cartridge installed.
If you do not have a replacement cartridge, and the quality of your printouts is not a concern, you can still print in ink-backup mode. Consider the following guidelines before printing in ink-backup mode:
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product will print more slowly and the colors in the printouts will vary.
    press OK button to clear the error message like cartridge missing after removing one cartridge.
Jun 20, 2011 | HP DeskJet F380 All-In-One Printer
Will the HP 2700 scan without an ink cartridge loaded? I am getting an error message about a problem with the black ink cartridge and it is overriding everything else. All I want to do is scan.
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP Photosmart 2710 All-In-One InkJet...
Why does the entire photo printout with a pinkage color overlay when indicating using glossy photo paper, even different photo paper. This occurs with several different programs not just Photoshop. I've...
That happens if you put photo cyan where the plain cyan ink should be, also photo magenta is too weak to be used in the magenta slot. I've also seen generic inks that weren't the right colors.
Jul 09, 2009 | Canon i9900 InkJet Photo Printer
HP 4600 has magenta and cyan marks on back of printouts.
YOU NEED TO REMOVE THE CARTRAGES AND THEN UNPLUG THE PRINTER. CLEAN THE INSIDE WITH RUBBING ALCOHOL AND SOME Q-TIPS.YOU HAVE EXCESS INK ON THE INSIDE OF PRINTER. THIS IS WHY IT IS GETTING ON THE BACK SIDE OF YOUR PAPER. HAPPY NEW YEAR TO YOU.
Jan 06, 2009 | HP LaserJet 4600dn Color Printer
MFC240C - all printouts in green colour
green is a combination of Yellow and Cyan, it is possible that you are missing magenta, depends on the file you are trying to print, if you can print one of each color this time print only magenta it would be helpful to isolate w/c is w/c from there you can find out what is the problem
hope this helps
Aug 08, 2008 | Brother Multi-Function Center MFC-240C...
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Shared HP 1020 Printing problem
Your question is not clear.
Please give some configuration info. e.g
Operating system?
Explorer Version?
Jul 15, 2008 | HP LaserJet 1020 Printer
My HP laserjet 1300 printer Problems
You could be set in draft mode in your printers properties, or, you could be using ECONO Mode.
Sometimes People use PCL Fonts for their printers, and other use PS Fonts. PCL is the typical font type. PS is post script, which Adobe type fonts are used.
If you are set to PS Fonts using MS Word, you might try PCL Font types instead.
Jul 02, 2008 | HP LaserJet 1300 Printer
My Canon PIXMA MP760 printer had been printing a horizontal stripe of a lighter cyan where ever that colour occurred. Today during printing it displayed an error. Unfortunately I didn't catch the number. I...
Maybe an obvious answer, but have you cleaned the print heads several times? You can also remove the cartridges, remove the entire print head and clean it with rubbing alcohol and a q-tip.
Mar 28, 2008 | Canon PIXMA MP760 All-In-One InkJet...
HP F380
Try cleaning your ink nozzles or ink jets. It sounds like you have a plugged nozzle or two. Your printer2.gif program2.gif should have maintenance options that allow you to test for plugged nozzles and clean them.
In control panel, open the printing/fax icon, right click on your printers4.gif icon, left click properties, then on the bottom of the page the panel that opens you will see a button that says printing preferences, and that should open your print1.gif program.
This will work for all printers, not just hp.
Nov 07, 2007 | HP DeskJet F380 All-In-One Printer
207 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
