Question about Sony PSP (Piano Black)
PSP joystick won´t work
Hey All.
Some days ago, I was playing "Wipeout Pure" on my PSP, and suddenly the joystick got jammed, it wouldn´t work correctly.  I therefore read all about how you could open the PSP, which I did, and I found out that it was broken :/ . Therefore I tried to do all kinds of stuff with the joystick (tried to clean it, place it "Correctly" etc), but it simply does not work. Now my question is:  Can´t I just completely remove the joystick module?
I recently bought a new game which can be played with BOTH the joystick and the normal directional buttons, so what harm would it be to completely remove the joystick module? - I am currently on vacation, so I can first get a new module when I get home, so will the PSP work proberly without the module temporarily?
Hope you can help :)
- Justh.
  • 24 Answers
It should work fine without it. Make sure you keep that little clear rubber part safe. It's what fills the gap between the analog stick and the motherboard on the PSP
Posted on Jun 16, 2009
I dropped my Psp 2000 three feet from the ground. It was turned off. When I turned it back on every character in a game that I play turn left. I have tried default settings and nothing has worked.
It sounds like the left button is jammed down, or the joystick is stuck to the left. The only way to fix this is to take the faceplate off and replacing the joystick module.
Mar 20, 2011 | Video Game Consoles & Games
When i try to play any game on my psp the joystick keeps moving down....and i took out the joystick and still does it...i play another game like final fantasy 7 on my psp that doesnt use the joystick and...
if you are facing problem in psp then just don't worry........... you can fix it with the help of repair guide you can download it and solve your problem easily...........
i will give you the link to download i hope it will solve your problem
Click Here to download
Dec 08, 2010 | Sony PlayStation Portable (PSP) Console
Psp help
Did you know you can use your PSP to pick up free wireless internet? Most people don't even realize this but it's pretty straightforward once you know how! Sit back and relax while you learn to get internet on your PSP!
Requirements:
There are a couple of fundamental things you will need before you can start surfing the web with your PSP. The first is some form of wireless internet source. It doesn't matter where it comes from, could be in your home or in your local Starbucks, all that matters is that you are in an area where you can get internet. Psp wireless settings follow the 802.11b wireless networking protocols, which are just about the most common in the world, so most kinds of wireless network connection will be just fine.
Also note that a copy of Wipeout:Pure is necessary to get internet on your PSP.
Sitting comfortably? Ok, prepare to learn how to get internet on PSP!
Step 1- Switch on the PSP and go to the System Menu, and then enter "Network Settings". From there go into "Infrastructure mode", and select a connection to edit. If you already have a home connection set up or something, just select this as the one you are going to edit. Leave the name of the profile as it is, and skip the WLAN settings if they are already set up.
Step2- Go into "Address Settings" click on "Custom" and be sure to leave "IP Address Setting" as Automatic. Believe me; adjusting this will not help you get internet on your PSP!
Step 3- Go into "DNS Setting" and click on manual. This is where we need to type the address of the web gateway we will be using. The most popular one to use for this is the gateway at Endgadget, so input the numbers "208.42.28.174" as the Primary DNS IP, and put zeros for the Secondary DNS IP. (0.0.0.0). If for any reason this gateway is not working you can usually find others with a quick Google search.
Step 4- In the "Proxy Server" options, select "Do Not Use" All you need to do from there is confirm everything, and save it all by pushing X when prompted.
Step 5- Launch Wipeout:Pure as normal, and go into the Downloads menu. When asked to select a connection, choose the one you have just been editing, and you should be presented with the Endgadget web screen. Et voila! How to get internet on PSP!
Provided you have the resource mentioned above, it's pretty easy to get internet on your PSP. Once you have it all set up you'll probably wonder how you got by without it!
Jul 27, 2010 | Sony PlayStation Portable (PSP) Console
Joystick problems
The only way this can happen is if you have damaged the joystick function area.You have to change the joystick and put another one.
Jul 22, 2009 | Sony PlayStation Portable (PSP) Console
My psp speakers dont work the head phone jack came loose and only plays out of one head phone and the up joystick doest go up all the way in a game so i walk slow, can i fix these problems and how ???
You have either what is called a dry joint on the headphone socket or the headphone socket is broken.
When you plug the headphones in it switches off the speakers, so if the socket gets damaged or becomes disconnected from the board the speakers will also not work.
you need someone with VERY good soldering skills and a spare headphone socket to repair or replace the socket
Couldnt say whats happening with the joystick, maybe a bit of the headphone socket has got jammed in it, you probably wont find out untill the psp is opened up
May 25, 2008 | RIM BlackBerry Pearl 8100
Getting on the internet
NOPe
if u have the latest firmware u should have a browse on it.
it will allow you to surf the internet, that wipeout game in not needed.
enjoy. Geeksquad
May 13, 2008 | Sony PlayStation Portable (PSP) Console
Grinding PSP joystick
you have to replace the joystick. do not use graphite as it will conduct accross the track. You need a thin philips srewdriver to remove 5 srews one under the label that says do not remove label in battery compartment.once all srews are removed cover pops out and its very easy to replace unit. Look on ebay for replacement joystick for SLIM MODEL PSP.
Feb 28, 2008 | Sony ACY-BR81/OB
How to set up psp to internet
hey...there, try this one and follow the instuction.
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly.
23. Launch Wipeout Pure and go to the Download option in the main menu.
24. Select the name of the new connection you just made (ex. WebConnect), connect, and enjoy browsing the internet on your PSP.
Feb 13, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
277 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
