Question about Brother PE-150V Computerized Sewing Machine
Set the timing
Machine will not pick up bobbin thread . the machine is out of time. I have a brother PE150 embrodiery machine. I need to know where and how to set the timing
Bbragg77 solution lacks a few points that I found out after talking to someone who repairs the machines.
Turn the balance wheel (counter-clockwise) so that the needle moves down and the hook is supposed to be spinning counterclockwise. As the needle reaches the bottom and starts to come back up, stop when the need reaches approximately 2 mm off the bottom. In this position, the point of the hook should be directly behind the needle.
Posted on Jul 25, 2009
    Sniper:
  • 52 Answers
Take off the bottom cover by removing 4 20 trox screws and 2 or 4 small phillips screws, the bottom part of the hook has two allen screws on it that can come loose causing you to lose timing, lower the needle all the way and then raise it a little bit putting the tip of the hook just above the eye of the needle and then tighten the allen screws and add some lock tight
Posted on Jul 16, 2009
The Allen wrench you need is a 5/64" and it also can be used as a approximate spacer for determing the the 2 mm gap needed
  • maureenrumml Jan 01, 2012
    Your answer was so helpful!! I tried it on my PE150 and it worked!!! Now I have another problem. The machine embroiders just fine but after a little bit it starts to go so fast that it breaks the upper thread. Any ideas?
    Oh by the way my husband was very impressed with your solution and my "ability to fix my machine". Thank you
My brother sewing machine special edition XL_5700 not picking bobbin thread
when installing a full bobbin make sure that there is at least 6" of thread outside the carrier slot
other than that check the needle /hook timing
Jun 18, 2016 | Brother Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
My brother pe150 embroidery machine does not pick up bottom thread and wont sew
try changing the needle
rethread the machine--use every thread guide
make sure the bobbin is not warped
make sure the bobbin is inserted correctly in the case
it's very possible that the timing of the machine is off & the machine would need to be checked at a sewing machine shop
Mar 20, 2012 | Brother Sewing Machines
How do you change the timing on brother pe150 as it wont pick up bottom thread
Full details on how to adjust the timing appear here in my Brother PE150 blog. You will need a few basic tools including the stubby screwdriver that came with your machine.
Mar 20, 2012 | Brother PE-150V Computerized Sewing...
Brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | Brother PE-150V Computerized Sewing...
Brother VX 1100 will not pick up bobbin thread...have cleaned and oiled machine and replaced bobbin case, could it be timing? It sure looks like it wants to work but just wont grab the bobbin thread.......
Replace the new needle, making sure the flat side is to the back of the machine.
Hold on to the top thread as the needle lowers and raises.
If it does not catch the bobbin thread, the timing may need adjusted.
You can find a graphic for adjusting the timing at sewusa.com, or take the machine in for service.
Mar 10, 2010 | Brother Sewing Machines
Brother PE150
You need to adjust your top tension and maybe your bottom tension ( the little screw on the bobbin cover) Also check your needle and make sure it's straight.
Feb 07, 2008 | Brother PE-150V Computerized Sewing...
Brother PE-150V Computerized Sewing Machine Logo
643 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
