Question about IBM ThinkPad T20 2647 Notebook
Want let me get on the internet
When you turn it onn it saids press F1 to setup bios setup utitity I have done that in put F 12 I have even try to reinstall windows but it want reask the disk are there anything else I can do . the laptop is a IMB Think Pad type 2647 .PLEASE HELP!!!!!
  • Caleb Judd May 11, 2010
    How do you connect to the internet? Dialup modem? cable? dsl? wireless?
    Most likely you need the drivers for your connection device.
  • 255 Answers
1. your laptop is working or not working..
2. if you have bios problem
3. change the bios battery
4. goto setup and restore the default settings
5. restart your computer
for more details: send your exact problem to
md_ehsan_1@yahoo.co.in
Posted on Jun 16, 2009
  • 31 Answers
Have you set the system time in bios after pressing f1? After that, it should start the operating system as usual, till the next system shutdown. It sounds like the cmdos battery is low and needs to be replaced. So the system date and time will be reset, when the computer is turned off and you have to set it every time you start your computer/laptop.
Hello sir, I have a problem with my Toshiba Dynabook 2140. I have changed its hard disk and I can't go to the bios setup menu how can I go to it. I have tried many times on hitting Del, F10, F12,...
Hussain - Greetings!
Do the following:
1. Turn on computer by holding down power button while pressing the ESC key.
The machine will beep, then display: Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
You should now have the BIOS screen
Regards, Mikeywaf
Mar 05, 2011 | Toshiba Satellite 2140CDS Notebook
My ASUS Eee PC 1005HA turned off by itself then when I turn it on again, a screen come up and said "press F2 or tab" but when i press each of them, nothing's happened. How can I fix that?
Hi I have almost the same problem as ame_91_ok with my Asus Eee Pc 1005Ha. It suddenly shut down a few days ago and ever since that time it boots the bios screen where you have to press F1 to enter setup or F2 to load with the default settings. If I press F1 I enter the bios setup and if I press F2 it's boots fine after that and it seems to work normally. Still I'd like to know what the problem is and if I can fix it before it might get worse. I don't know anything about bios settings or anything like that so I could really use some expert advise. Already tried updating my bios, I have the latest bios version now but that didn't fix the booting problem.
Greetz 08Ray
Dec 31, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Iam at black screen that said F1 to resume i pressed and sendme to bios utility how can i go back to regular screen windows
What was the error-message just BEFORE that 'F1' message?
Turn the computer off, wait, and turn the computer on.
If you get into BIOS SETUP,
use the "arrow" keys (UP, DOWN, LEFT, RIGHT)
to highlight the 'Load BIOS defaults' menu-item.
Press ENTER to apply that option.
Use the arrow keys to select "Save and Exit from BIOS setup".
Press ENTER to apply.
Oct 24, 2010 | Computers & Internet
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Aug 26, 2010 | Intel Motherboard
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Can't get into the bios for a presario 4716
This is what the Compaq site had to say about the BIOS utility for your system (Source: Compaq): • • • •You may have difficulty accessing the BIOS Setup utility screen, because you must press a specific key(usually F1) very quickly before the Windows screen appears. If you do not enter the BIOS Setup screen on your first try, repeat the following steps until you are successful.
To open the BIOS Setup screen:
1. Turn off the PC and wait about 5 seconds.
2. Turn on the PC.
3. When the first screen appears, press the F1 key on the keyboard. (You can press the key more than once.) The BIOS Setup Utility Main menu appears.
NOTE: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
4. Use the keyboard to navigate through the menus.
You may need to remove the battery and then back in.
Jul 21, 2009 | Computers & Internet
Cannot enter bios setup
pres del or f1 f2 f4 f 12 but not press esc.then check if u still get rpoblems then u have to reset you bios settings .u have to remove your cmos cell for 15 minutes it is in back side of laptop.
Jan 24, 2009 | Toshiba Satellite 1415-S173 Notebook
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or Ctrl+Alt+Esc
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
IBM ThinkPad T20 2647 Notebook Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
