Question about HP VECTRA VLI8 P3 Motherboard (KZM6120)
Meamory overflow hi, i have a pentium 4, winxp home, laptop...i want to reformat my hard drive...but when i place the boot cd i get a 'memory overflow error message'...could you please tell me what i should do
  • Caleb Judd May 11, 2010
    is the memory overflow error on a blue screen? what is the error number? at what point in the process does the error come up?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Swap out the memory in your laptop with known good memory and see if that takes care of the problem.
  • HP Master
  • 3,267 Answers
How much data is there on the HDD. Delete more files and C drive should be max 70% loaded. After that run the bootable xp Cd & go for a clean installation. You should succeed, else try Hiren's boot disc and try to scandisc for HDD errors if any...............sodeep
Posted on Jun 16, 2009
How to reformat pentium 4 2.8g to windows xp
Since Windows XP isn't a filesystem, that doesn't quite make sense, but it sounds like you want to find or buy a Windows XP DVD, put it in the machine's DVD drive, enter the BIOS to check your settings and set it to boot from CD-ROM (it works for DVDs too, after all,) save settings and reboot...then install WinXP.
Keep in mind that if you have unsaved data on the system's hard drive, you would want to swap it out for a new one until Windows XP (or Ubuntu, or Fedora 15, much more modern OS which are quite capable of running WinXP programs using a program environment called 'wine' (no relation to drvino.com)) is installed; that way you're not going to overwrite old stuff you wanted to keep.
Then you can install the old drive on whatever interface is handy and migrate your settings over, make backups, use the old drive for pagefile or to try new filesystems and virtualization environments, etc.
May 23, 2011 | Microsoft Windows XP Professional
I was running Windows XP Professional with motherboard drivers given on purchasing the computer. Then I installed Windows 7 Ultimate and the drivers are not working. I'm on Intel Pentium 4 series. When...
Hi, the problem here is that you may well not find the drivers for windows 7, and to re install XP you will need to reformat your hard drive; for this you will need to change your primary boot device to CD Rom, and then boot with your XP disk in drive, selecting boot from CD when it appears. Re partition and reformat and after reboot it will start to install XP.
Hope this helps
Sep 09, 2010 | Intel Computers & Internet
Motherboard DFI CA64-SC windows XP compatible? Just reformatted and delted all partitions and did fresh win98se install. Last time though I thought I did this and winxp seemed to install but then came...
You need to establish how much memory is required, more the better.
The minimum hardware requirements for Windows XP Home Edition are:
  • Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
  • At least 64 megabytes (MB) of RAM (128 MB is recommended)
  • At least 1.5 gigabytes (GB) of available space on the hard disk
  • CD-ROM or DVD-ROM drive
  • Keyboard and a Microsoft Mouse or some other compatible pointing device
  • Video adapter and monitor with Super VGA (800 x 600)or higher resolution
  • Sound card
  • Speakers or headphones
http://support.microsoft.com/kb/314865
Aug 26, 2010 | Computers & Internet
How to set up windows xp to laptop without using cd rom
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.
http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON
http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Thankyou
Amit Bhardwaj
May 08, 2010 | Microsoft Windows XP Home Edition
Reformatting a drive
The BIOS has nothing to do with reformatting a drive.
If you are doing a system recovery, placing the recovery disks in the CD/DVD will do the job for you. You just must boot from the first recovery disk or, in some computers, choose the recovery option at startup--this uses a recovery partition on the hard drive to do the recovery for you.
Mar 24, 2010 | Acer Aspire M1640 Refurbished Intel...
What is the drive type used in the Toshiba 2415 S205 laptop?
Specifications of TOSHIBA Satellite? 2415 Series
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Home
Satellite 2415-S206
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Pro
Performance
Mobile Intel® Pentium® 4 processor-M at 2.00GHz
Memmory 256MB expandable to 1024MB
All-in-one design
40GB* hard disk drive
DVD-ROM/CDRW multi-function drive
Mar 15, 2010 | Toshiba Satellite 2415-S205 Notebook
My toshiba TE 2100 will not start. it goes through the startup procedure then shuts down and does it over again. I would like to reformat the drive but can't seem to get it to boot from the cd. what should...
go to the bios by pressing F1, F2 or Delete button.
set first boot device a cd rom.
if this still not work then change the cd rom.
dont forget to vote.
Sep 14, 2009 | Computers & Internet
Reformat
step 1 - First insert the windows xp cd in your cd drive.
step 2 - Then start your computer and keep pressing F12 key on your keyboard.
step 3 - After pressing F12 key,it will show you some options to select from where you want to boot from.
step 4 - Select 'Boot from CD drive/USB cd drive'
step 5 - Now it will try to boot from your bootable windows xp cd which you have inserted in th CD drive.
step 6 - After reading the CD it will prompt you to 'Press any key to boot from CD drive'
step 7 - At this moment press any key.Remeber you will have to press any key while this prompt appears.otherwise it will boot from your Hard disk drive.
step 8 - After pressing any key it will start windows xp setup.
Thanks
Feb 12, 2009 | Dell Microsoft Windows XP Home Edition
PM800-M2 Restarting
reformat means that you have to install an fresh copy of your operating system to the hard drive. if you do have a cd of your windows installer like windows xp, just put it in your cd drive and restart your computer and boot from that cd. be sure to erase the partition that has your corrupt operating system installed ok to replace it with the new xp that your going to install...
that wasn't to hard was it?
Apr 30, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Reformatting the Toshiba Satellite 5005-S504
you did not specify what operating system you are currently using, anyhow, if you are using winxp, configure the bios setting set the cd rom as your 1st boot device and insert the winxp cd to the cd rom then save and exit the. computer will automatically reboot after exit. a message will appear "press any key to boot from cd" you may press a key. you follow correctly instructions or message from the screen then you will succeed. hoping that this will help you. if you have some queries you may send me thru my e-mail.
Dec 28, 2007 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
290 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
