Question about Sony KP-51WS500 51" Rear Projection Television
Hitachi tv 60fx32b comes on then turn red - Sony KP-51WS500 51" Rear Projection Television
Focus hitachi 60fx32b was watching this tv and it suddenly turned off and wont power back on
Try to plug it into a different electrical socket and try it without any extension cords or power strips (sometimes the socket or extension cord is to blame)
Oct 19, 2013 | Samsung PCJ522R 52" Rear Projection...
How to move red line on a hitachi 60fx32b
Convergence is adjusted with Hitachi remote and to get into mode you remove speaker grill (on model indicated) and locate small blue button on front of chassis--with set on press button and grid of lines comes on.
If red is really bowed and will not adjust----the convergence chips need to be replaced.
Feb 19, 2012 | Hitachi Televison & Video
Hitachi 60fx32b out of focus how can i fix it
If not a convergence issue: each tube (back of set) has a large black lens with a wing nut on side----loosen nut and rotate lens slowly until red is in focus.
Feb 19, 2012 | Hitachi 60FX32B 60" Rear Projection...
Need to find manual.
need a manual for a HITACHI DZMV550A camcorder
May 18, 2009 | Sprint Hitachi P300 Cellular Phone
Hitachi 60fx32b is dead with no lights on front panel
The two other fuses look like resisters. My suggestion would be to check them first and if bad use a temp of the same rating to see if it was just a power surge.
Apr 14, 2008 | Hitachi 60FX32B 60" Rear Projection...
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60fx32b rear projection
When you turn on the TV do you hear 3 clicking noises then the TV turns off?
Jan 12, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60FX32B picture
Replace vertical output IC with first quality part,check caps
in vertical power supply......If you don't have access to parts,
then solder pins of IC,should hold for awhile.
If you need further assistance, let me know.....T.
Oct 26, 2007 | Hitachi 60FX32B 60" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
