What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
  • 355 Answers
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Posted on Jun 16, 2009
  • khairulasma Oct 26, 2010
    water cant stop while level indicator `on`
I have washing machine model Dwf 772w........where i want get a spare part because a WS not function anymore.....how much that spare part....i think that about computer box
Posted on Oct 31, 2011
  • Julian Vazquez
    Julian Vazquez Dec 31, 2013
    Another services company that is very good,professional and most important are very honest and cheapest are YINO SERVICES AND REPAIR INC. their phone number are (786)4024946 and (786) 5436377
  • Julian Vazquez
    I'm forget something, they are in Hialeah too.
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Error message " LE "
Click the link below to troubleshoot the LE error on your daewoo washing machine:--- http://technoanswers.blogspot.com/2011/06/le-error-on-daewoo-washing-machine.html ----------- This should help.Thanks.Helpmech.
Jun 01, 2011 | Daewoo Washing Machines
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Apr 20, 2011 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
Dwf-6010ap
I HAVE DAEWOO WASHING MACHINE MODEL DWF-6010AP
THE PROBLEM IS THAT COLD INLET IS LEAKING WHEN RUNNING I NEEDS SOLUTION OR WHERE CAN I GET PARTS
Jun 25, 2008 | Daewoo Washing Machines
Daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
May 23, 2008 | Washing Machines
Washing Machines Logo
1,595 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
