Question about LG 37LC2D Television
Well my LG lcd 37" powerson for a few minutes then loses signal, i go to turn it off with the remote and it takes about 20 seconds to turn off, and when turning it back on it blinks freen about 15 times and it turns on but no signal from the fios box. non of the buttons on the side of the tv responds or on the remote respond when it does this, i leave the tv turn off forr about a hr and try to turn it on and it does but only for 10 to 15 mins. help!!!
    President:
  • 1,383 Answers
It hink there issue with loose connection in circuit or any dioade , register or transistor is blown on circuit.
But first check your power supply and earhing work properly.
Posted on Jun 16, 2009
The tv takes 25 minutes to turn on. it shows no signal, makes loud crackling noises and then turns on
i would look at the power supply as it sounds like the caps in it are getting weak
Oct 14, 2009 | LG Z37LC6D 37 in. HDTV LCD TV
Samsung LCD takes about 7 minutes to power up after tv has been off all night
My tv was taking about 7 minutes to power up. Then it was taking 20 minutes and now it's not coming on at all.
Jun 12, 2009 | LG 37LC7D 37 in. LCD HDTV
Losing signal intermittently every 1-5 minutes
This problem is probably due to weak signal strength from the cable to the television. Buy a signal amplifier for you cable line in and use another cable out of the amplifier output to your Television input signal source, This should bring up the signal strength for you.You could also have your cable company check the input signal strength to you house or apartment and see if the cable itself needs repairing or replacing.If this does not help with your problem , then you need to have your television tuners signal input circuit tested it may have weakened from age. This may be adjustable in the tuner box, but this is something for a service technician to determine. customer service number for Insignia is 1-877467-4289. Hope this helps you with your problem
Apr 20, 2009 | Insignia 37" LCD Flat-Panel HDTV
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
Delayed signal to my lcd from the cable box.
It is not that rare to have a few secound delay but it sounds like yours has some componates that have gotten alittle hot at times and now take longer to come up if you haven't put a surge protector on it I would do so . To day with all the brownouts and power spike the newer units can not handle this couse of the componate being a lot smaller and as we put more and more ecectronic in our homes we create are own power drops the only way to help this in most homes is to use surge protectors.
oldgrizzly
Nov 11, 2008 | LG 37LC7D 37 in. LCD HDTV
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
My 2 month old 37" LG HDTV won't turn on...
just resolder capacitor then use a pc fan on iy
good luck
Dec 06, 2007 | LG DU-37LZ30 37 in. LCD HDTV
Black and white picture, then color, need to warm up?
Your tv has a factory defect take it back to the store you bought from if it is under warranty.how ever there was a bad manufacturing of tha tv the components in the video circuit has some lose connection they need to be resolder.if you take it to a repair shop the warranty will be void.goodluck.
Mar 23, 2007 | LG RZ-37LZ30 37 in. LCD Television
Televison & Video Logo
69 people viewed this question
