Question about Bang and Olufsen Beosound 4000 Shelf System
Beocom 2400 earpiece soundcable problem
Handset earpiece works intermittently. When it works, sound quality is fine, it just comes and goes silent periodically.
Appears that there is an internal loose connection becuase, if I gently pull the wire leading into the handset, the sound will usually fail. Gently press it back in, sound returns.
So, problem is: When I slide the silly plate off the handset a) there does NOT appear to be any cable clamp/grip working (which is why I guess this problem occurred in the first instance!) and, b) I cannot 'see' any obvious way to open the handset (e.g. part the red and pale grey front/back portions) in order to access and re-attach/solder any dislodged wires and/or install a sensible cable clip.
Advice please?
  • 22 Answers
Hi I also had a problem with the wires breaking on the handset of my Beocom 2400 , and I could not find out anything on the Internet .
But I managed to fix it without to much difficulty !
So I thought I try and help people in the same situation out !
Anyway to split the handset you will need a plastic card , like a credit card , store card etc) as in picture . DO NOT USE anything made of metal !!!
You will need to start at the bottom of the handset where the microphone is ,on the right hand side looking at the front of the handset .Insert the card,only a little way about 10 mm, then draw the up where the seam is , once it has started to separate you will find it will become easier as you work you way round .
Once you have separated the two halves you then need to peal the outer casing off the cable find the break cut it out and solder the wires back together ,I used heat shrink to cover the bare wires as in picture .
When you have done this it is just a case of sticking the two halves back together , Don't use instant glue!! use a glue which will give you time to position the two parts as it is not that easy , then clamp the two parts together with cable ties , as in picture .
Clean off any glue ,leave for glue to set remove cable ties , job done .
I hope this has been of help to someone!
Regards Stuart . dorsetpicture.co.uk .
http://farm3.static.flickr.com/2460/3814339247_8767c2aa31_s.jpg
http://farm3.static.flickr.com/2444/3814339347_83180a9499_s.jpg
http://farm3.static.flickr.com/2513/3814339477_9577cf01d2_s.jpg
http://farm3.static.flickr.com/2447/3814339721_72d7e68176_s.jpg
http://farm4.static.flickr.com/3556/3814339799_b30d7d805a_s.jpg
http://farm3.static.flickr.com/2461/3815149182_c31a69fc0c_s.jpg
I take no responsibility if you bugger it up ....
Posted on Aug 12, 2009
How to change the battery of Beocom 5 handset?
contact Beocom it might have to be sent to them to change out
Dec 10, 2017 | Lands Phones
How do i turn off the silent mode
To turn the Silent Mode OFF for your handset to ring, press and hold the # key on your handset for about 10 seconds. Your handset will beep and this will indicate that the Silent Mode has been turned OFF.
Jun 21, 2015 | Uniden DECT 6.0 Cordless Telephone...
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
Which is the best earpiece for mobile
From experience, bluetooth wireless headset is the best. However it may not be handy in listening to the radio. You can try to swap them with others of the same type but be aware of fakes. Fake ones will not pick radio signals.
Dec 30, 2011 | Samsung S8300 Ultra Touch platinium-red...
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
THE HANDSET HAS NO SOUND.THE SPEAKER PHONE WORKS FINE
Please open the handset and check the earpiece. It can be due to a failure of the earliece- test with a meter- or a failure in the board.
Mar 29, 2011 | Cell Phones
I have a new phone model lg km555, but unfortunately after 3 weeks i wasn't able to hear any sounds from it. its like in a silent mode. but i tried it with headset, it works. what can i do?
The earpiece is not functioning or the speaker is not working accordingly. Remove the panel to check the earpiece if faulty replace, if not check the connector, the connections to the earpiece jack section as since the headdphones are working there can be a break inthis section. Use a lens to check carefully.
Sep 14, 2010 | Cell Phones
My Beocom 6000 table base unit no longer charges
If your base has a charge indicator on it and it indicates that the handset is charging when the handset is in the cradle, I would say you need a new battery. RadioShack sells a replacement battery for $22.00 at the following link
http://www.radioshack.com/product/index.jsp?productId=2815547&CAWELAID=107599274
If the charge indicator doesn't come on it is unlikely that it is the battery. You may be able to get the phone repaired by the manufacturer but it may be better and more practical to get a new phone.
Jan 07, 2010 | Lands Phones
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Problem with B&O beocom 6000 ''extension'' no contact with base
I think you just need to re-register the phone to the base. Press the button on the base station (between the 2 charger pins) then go to the handset setup menu, scroll to register handset.
Feb 25, 2009 | Lands Phones
412 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
