Question about StarTech.com (ATXPOWER400) 400-Watt Power Supply
Power supply won't turn on
My PSU will not turn on.
It was working fine until I unplugged it to move the computer.
The LED on the mobo is lit so power must be going there. But I can't get power to the fans and drives....? I tried a different power cord and that didn't work. I tried unplugging my USB mouse but that didn't help.
  • hyphenguy Jun 16, 2009
    I'll try what you suggested. I added a hard drive a week before this happened. Maybe that pushed it over the edge?
    It's frustrating because I have an old computer that still works and it's 10 years old with original parts!
    Novelist:
  • 166 Answers
You may have a failing motherboard or power supply unit (PSU) then. Just because a mobo has a light on it does not mean that it is getting enough power, just enough to turn that light on. Failure of motherboards and PSU's are usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. There is something in the computer that is not getting enough power and causing it not to start. There are a few companies that will repair broken capacitor issues, if you find that you have that problem. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail. Have you added any big video cards or extra drives?
And remember a bad PSU does not mean no power, just not enough to run the computer. If you replace the PSU make sure that you replace it with one of the same or greater output watts. Output Watts should be listed on the outside of the PSU itself.
I would try another PSU first if the mobo caps looked good.
Posted on Jun 16, 2009
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Mainboard: g31 m7 te - power: antec hcg750 - gpu: gtx560ti
No the mobo is compatible with the Power Supply, and GPU.
And vice-versa.
Mainboard fan???????
You mean the Processor (CPU) fan?
I'm guessing I guess, because computer case fans aren't on the motherboard/mainboard/mobo.
(MOtherBOard)
You're getting power to the mobo, but the question is how much?
1) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
http://206.108.48.60/app/en/mb/introduction.php?S_ID=363&tab=1
The mobo will support Intel Core2 Quad-Core processors. Depending on which one, you may be talking about Up To 105 Watts of power,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Quad-Core_Desktop_processors
This is why LED's can light, and fans may spin, but the Processor isn't getting enough power, so the computer will not turn on. (Processor isn't turning on)
Why?
1) Just because that Power Supply is new, doesn't mean it is good.
Sometimes you get a bad one. Test the three main voltages coming out, with a multimeter set to DC Voltage.
Need guidance post back in a Comment.
(An economical multimeter can be purchased, for as little as $8 to $12. I have seen cheaper. Available in a multitude of stores. An auto parts store is but one example )
2) You don't have the 4-pin ATX +12 Volt power cable plugged in.
Goes to the white square 4-socket hole connector, to the left top corner of the Processor socket.
(Motherboard installed in computer case)
3) REQUIRES -> TWO 6-pin PCI-Express power cables, for the Nvidia GTX560Ti graphics card.
The Antec HCG750 PSU has 4 of them, so no problem there, IF you have two of them plugged into the graphics card.
Both connectors of the 20 + 4-pin ATX main power cable's connector, need to be used. Biostar mobo requires a 24-pin ATX main power cable.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
Post back in a Comment as to power cables plugged in, and DC Voltage test on PSU.
Regards,
joecoolvette
Aug 06, 2012 | Biostar G31-M7 TE Motherboard
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
I can't get my computer to boot up
If the led is flashing then you can unplug the 20 pin or 24 pin depending on model and led stops flashing and becomes bright then most likely psu is ok and you have a mobo issue. Had 2 pavilions do this now and rather than replace mobo i fiddle with psu cord and mobo connector. If you can get the cpu fan to click and briefly spin you got connection and can power up unit. This takes a great deal of patience unless you just get lucky. Used to work every timefor me until i got smart and pavilions are all on battery back ups now.
Oh ya btw this issue once it happens will generally happen every time you lose power hence the back ups good luck if if there is enuff demand for technique demonstration perhaps I'll make a utube video
Feb 16, 2011 | HP Pavilion ze4300 Notebook
Motherboard no power
In this order:
check PSU is working ( fans run in the psu), test with another psu installed,
See of there is a green LED lit on the mobo
Check capacitors are not bulging or leaking and there are no signs of burned circuit traces on mobo
remove ram and try booting see if you get power to the cpu fan
try bypassing the PW switch and touching the PW terminals on the fpanel header to eliminate swith problem.
If that fails, suspect dead mobo
Jan 11, 2011 | EliteGroup ECS P4M900T-M2 Socket 775...
Hi there. I have issue with this mobo regarded to pwrLED which is not ON even with the PSU plugged in. Actually what is happening is that as I turn ON the PSU main switch sometimes i get light from the...
In my experience you may need to replace the case but if you feel up to the challenge you can clean the contact headers on the MOBO for the PW LED and try reseting the CMOS for the bios.
Mar 20, 2017 | ASUS A7V266-C (A7V266-C W/A) Motherboard
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
No boot up.
Power supply is easier to troubleshoot my local pc shop has used ones for $5 or if you have one laying around make sure you have one with the proper mobo connector 24pin will sometimes fit 20 pin as long as there are no transistors to close to plug just turn pc off unplug all drives and mobo plug in good supply and turn on if it works thats the problem if not probably mobo
Apr 10, 2009 | Shuttle SK43G (tsk43g) Barebone
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
StarTech.com (ATXPOWER400) 400-Watt Power Supply Logo
111 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
