Question about Protron PLTV-32 Television
Tv won't turn on, we were watching the tv and it turned off by itself and wouldn't turn back on. electric is good etc.
  • 157 Answers
If there is no standby light then it is likely to be the fuse inside the tv. If there is a standby light then it could be many various things.
Posted on Jun 16, 2009
Philips digital tv won’t turn on.
unplug from electric, wait 30 seconds, plug back in. Check that you have power at the outlet (fuse/breaker shut off?) If it has a power word which plugs into the TV as well as the wall, be SURE it is tightly attached to BOTH. Make sure you aren't blocking the remote control receiver (you can turn most TVs on/off on the TV itself -- look for a power button). Be sure your remote has fresh batteries. Good luck!
Jan 14, 2018 | Philips Televison & Video
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
How do I remove the stem from the automatic
mcdevito75 here, You can remove the stem from your Seiko watch fairly easiky, however if your not familiar with the inside of a watch, I wouldn"t attempt it as you can easily destroy the watch. If you are a bit familiar with the workings of a watch, at least know that this is the balnce wheel, this is the hairspring, gear train etc. when you look at the workings of your watch then you should have no problem. If you are not familiar with the watches works I wouldn"t attempt it. But here goes, Lay the watch crystal down on some paper towels, clth. etc. something to cushion the watch, after you remove the back cover, and Movement cover, note the stem and it"
s position in the watch, just about next to the stem as it goes into the watch movement you"ll see a very small screw, veery small, with Jewelers screwdriver turn that screw 1 full turn, Gently try to remove the stem, do not use any force, if the stem does not come out, give 1 more turn on that screw, try to remove stem again, if not, give half turns on that screw 1 at a time, after each half turn try to remove stem. When the stem does come out do not touch that screw anymore. DO NOT REMOVE THAT SCREW FROM THE MOVEMENT, AS THE MECHANISM HOLDING THE STEM IN THE WATCH IS UNDER THE FACE (DIAL) 1 full turn on that screw the half turns, checking after each turn to remove the stem. You should have a magnifier glass and jewelers screwdrivers to do this job, all available over ebay. If your not familiar with watches, look for a small watch repair shop in your area for repairs.
Jul 22, 2010 | Seiko Mantel Clock
Daewoo TV Dead
STARTING: fuse, swelled capacitors, voltage reading on the output of the power supply board. In that order. BE CAREFUL the power supply board is the one that plugs in the wall and has 120 volts on it. The output should only be 5 and 12 volts etc. If you have nothing there, that's a good thing, the rest of the TV is probably good.
WARNING: This applies only to a modern, flat TV. If it's a older CRT type, they have up to 50,000 volts in them and will KILL YOU.
Aug 24, 2009 | Televison & Video
ILO TV turns off by itself.
Is your sleep timer activated? Check your menu settings. Or maybe some kid with a universal remote turning it off? Try covering the remote sensor with duct or electrical tape and see if the problem persists.
May 26, 2009 | iLO 3200 32 in. LCD Television
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
27 inch Digimate LCD TV Shuts Off Automatically
have you had this probelm fixed mine just starteed to do it and its only 8 months old and I cant afford to have it fixed please help if you can thanks
Feb 04, 2007 | Digimate DGL26 Television
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Protron PLTV-32 Television Logo
150 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
