Question about Polycom PVX (515122019001) for PC
PVX Desktop VC Software is not detecting the ibbuilt camera of So
When we start PVX, the camera should be detected. While the camera works standalone, the PVX is not detecting and hence we have to connect external camera.
  • Yannick Verhoog May 11, 2010
    Have you installed the drivers for the camera?
How to get rid of bing.vc on windows 7
Go to the installed programs list, wait for it to populate and then find that program. Click it on and select unistall. That will remove it. Follow the list below:
Control panel - programs - uninstall programs .
Aug 13, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Recently I bought the Canon Ixus 220 HS compact camera. With the camera I received some software among other things Zoombrowser ex. Regretfully this program doesn't work properly from the start. When...
Is your Camera detected when connected to the PC via the PTP in the Device Manager? Check your "Device Manager". In Windows 7, sometimes the camera is not detected, but you can try "Workaround when the camera cannot be detected by Windows 7(when connected via PTP)". If the device is not detect in the Device Manager the software will not work.
The update is only for the software ie Zoombrowser(Win7x64) -> update to version ZoomBrowser EX 6.7.2 Updater.
Hope it helps & good luck.
Jun 08, 2011 | Computers & Internet
Authentication by Face capture by webcam
For you to be able to do this you would need a separate standalone program. Your web application would try to detect if that program is running or installed on your client's computer if it is then your webapplication would send a request to the local application to run the face capture, if not then your webapplication would require the download of the software.
With regard to your local standalone software. you could do that in visual basic. make sure that your standalone code would also be a small webserver.
so what your web application actually does is it sends a request to the localhost or client computer, assuming that the local standalone is present then your webapplication would be able to connect to it through the small webserver. Well, the main point is that the local software would be the control for the webcam and also the means fo communication between it and your web application.
Apr 16, 2010 | Microsoft Visual Basic Professional...
My Nikon Coolpix LP16 is not detected by Windows on either my PC or my son's laptop, but IS detected by our Mac laptop. I've tried different ports, different cables, reinstalled software, reset the camera...
Microsoft updates frequently make changes to the registry which cause our cameras to no longer be recognized. The simple solution is to start using a separate card reader.
Mar 31, 2010 | Nikon COOLPIX L18 Digital Camera
Camera wont work, wants me to close apps and try again
Sounds like you may have a corrupted java system. Try to reload the OS by going to the Blackberry.com website, an downloading the desktop manager 4.7 fairly large, as well as the Blackberry device software. Depending on Carrier it should be the 4.5 version. Install the desktop manager, then install the handset software. Plug the phone in let it detect the settings, and then use the application loader to reload the handset software. It will back up your settings, and applications, and restore them once it's completed.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Digital camera driver
Hey Buddy
what u cann do is you can uninstall the software from add & remove programmes,incase you are not able to do so than follow these steps:-
  1. Click Start, Run and type regedit.
  2. Within the registry, open the below key.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
  3. Within the above registry key, select the program you wish to uninstall from the right side of the window. and delete that.
While using this option make sure that u are only making changes to those options which u know otherwise it could effectyour OS.
After that install the software that u have got with the new camera and than try to transfer the pics.
Thanx
Gizmo
PLz vote if it helps
Dec 20, 2007 | Microsoft Windows 98 for PC
Camera recording software
how can i get it . solve my problem
Aug 30, 2007 | D-Link DSC-350 Digital Camera
Computers & Internet Logo
337 people viewed this question
Top Polycom Computers & Internet Experts
Darren  Means
Darren Means
Jack Frost
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
