Question about HP DesignJet 500ps (42 in.) InkJet Printer
Error code 79:04
Hello im Alexander my problem is on hp designjet800 when switch on the plotter and is getting ready then the error 79:04 i wll be greatful for your support
    President:
  • HP Master
  • 1,314 Answers
From the service manual:
System Error: 79:04
Problem Description: Firmware Error.
Corrective Action: Try the following:
Switch the Printer Off and wait a few minutes. Switch the Printer on again and check if the Error Code has disappeared.
If the Error Code reappears, check for a new Firmware release.
The firmware upgrade and tool can be found here.
Posted on Jun 16, 2009
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
Hp designjet error message 5.10
The 04C*** error is an internal data bus error. The hard disk drive and the Jetdirect card share this bus. With the power off, disconnect the HDD and remove the Jetdirect card. Power up and see if the error goes away and the plotter goes to ready. If it does, put the HDD and Jetdirect card back into the plotter one at a time and power up again to identify the failing part. If the error continues with the HDD and Jetdirect card removed, the bus controller has died and the main logic board needs to be replaced. Any of these parts can be ordered from: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
I can also be reached at 800-959-1575 to answer questions.
Apr 24, 2014 | HP DesignJet 500ps InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Hp design jet 500 error code 5613?
System Error: 56:13
Problem
Description:
Error in the Drive Roller Encoder Sensor quadrature.
On again and check if the Error Code has disappeared.
If the Error Code continues, replace the Drive Roller Encoder
sounds like the media motor encoder is dirty or has failed , there are videos on you tube on how to get to the sensor ,OR if your not up to it I would recommend Belmonte Business equipment as being much cheaper than HP to resolve your issue
Nov 29, 2012 | HP Hewlett Packard Designjet 500 42" Wide...
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Hp designjet 450c error lights
Take all cartridges out while the plotter is on,then re-insert them one by one and watch the ready light flash after each insertion.If it doesn't flash that could mean 2 things,either the cartridge is bad or the contacts on the carriage are dirty or the entire carriage needs replacing.
I tell all of my dj-4XX customers to check the spittoon assembly(on the inside,right side)for ink buildup. If it looks clogged,you can temporarily scoop the ink that solidified out,but eventually it(spittoon)will need replacing.
Hope this helps
Jan 09, 2008 | Xerox Phaser 7750DN Laser Printer
HP DesignJet 500ps (42 in.) InkJet Printer Logo
4,345 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
