Question about Canon PIXMA iP3000 InkJet Photo Printer
I need help with installing ink
Pixma IP3000printer
  • 157 Answers
Open the front cover when the printer is turned on, wait until the ink tanks move to the change position. push the clip on front of each tank in and lift the tank up. take the tape off the new tank cartridge if it has one (only if it says to remove it) put the cartridge in and press down until it clips. close the front cover and the ink will return to its normal place and initialize
Posted on Jun 16, 2009
How to remove ink?
Depending on the exact Canon Pixma model (there are many, for example, Pixma MX340, Pixma MP280, Pixma MG3220), the method varies.
Here are three YouTube videos on how to change the ink of 3-different Canon Pixma printers:
Changing Ink Canon Pixma MX340
Canon Pixma MP280 How to replace printer ink cartridges
Canon Pixma MG3150 How to set up and install ink cartridges
Jun 06, 2014 | Canon PIXMA Office Equipment & Supplies
Pixma scanning erro code 4,202,14
Here are error codes for Canon Pixma MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
maybe this will help you to localize the problem.
Jul 10, 2012 | Canon PIXMA MP160 All-In-One InkJet...
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
EROR 5 OF LINE
E 5 says the wrong ink is installed or the ink is not installed properly. Canon will replace if it's canon ink, if it's a generic or a refill, you need to take it back for exchange.
Jun 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma ip90 green light flash then orange light flash 4 times then back to green
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Aug 07, 2008 | Canon PIXMA iP90 InkJet Printer
Installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Apr 04, 2008 | Canon PIXMA iP1600 Printer
My Canon PIXMA MP830 all-in-one is saying "the type of printhead is incorrect, install the correct printhead."
The cartrige is what holds the ink, the printhead is the device that puts the ink onto the paper.
So if your out of ink, then you need a new cartridge, if you have a new cartridge and you are having issues printing good quality, then you may need a new printhead.
you can get the ink here: http://printerinkcartridgesearch.printcountry.com/canon-pixma-mp830-ink-cartridges.htm
printhead is about 49.95
http://www.precisionroller.com/k_canon_pixma_mp830_print_head/m114d8577c104/
Hope this helps!
Brad Nelson
Mar 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP500
When installing or replacing an ink tank, only one of the ink tanks should be installed. If the ink tank is not installed correctly, an error message will display.Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
Give a thorough check up to confirm any colour ink is not twice loaded (cannot be loaded in a single slot,may be in another slot )
May be any defective ink cartridges
Mar 13, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP830
pleaz alihn the new cartridde by programing or change the ink ,it may be dry
Sep 14, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
77 people viewed this question
old marine
old marine
