Question about Epson Stylus Photo R320 InkJet Printer
Printing Streaky My Epson R320 is not printing correctly. I do the nozzle check test and the black has a few gaps in it no matter how many times i clean the print head (same spot each time). When I print a page of text, for example, the page has "lines" in it where the ink did not print and the parts that did print, the ink is faint. Another example is when i printed a photo of someone in a (solid black) tux, the photo came out looking like he was wearing brown pin stripes. Is it the ink or the printer itself that is malfunctioning?
  • 157 Answers
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Posted on Jun 16, 2009
My Epson R320 prints yellow over everything
One key diagnostic you need to perform is a nozzle check. This will tell you what has happened to the other ink colours as much as indicate if yellow is polluting other nozzles.
You can run a nozzle check from Printing Preferences > Maintenance.
Once it has printed you should (normally) see a sort of stepped grid pattern similar to this.
If you can scan or take a photo of the output and the post it as a follow up it'll then be possible to get a bit more of an idea of what could be happening.
Jun 30, 2013 | Epson Stylus R320 Digital Photo Inkjet...
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Color differences
i apologize for the inconvinience.
the possible reason why its printing the right color, is bec. some of the nozzles might be clogged by dried inks, so when inks come out, the combination of colors are not balance. try printing a nozzle check first, if the nozzle check have gaps or breaks, try head cleaning, nozzle check after it so you can see if it improve or still w/ gaps, just do nozzle check, head cleaning, then nozzle check, head cleaning alternately until no more gaps then try to print.
Printing a nozzle check pattern
Load paper in your printer
In SelecType mode, press the Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button until TEST PRINT is displayed on the LCD panel, and then press the SelecType button.
Press Paper Feed (fontu1.gif) or Paper Feed (fontd1.gif) button to display NOZZLE CHECK
Press SelecType button to display PRINT
Press the Enter button. The nozzle check pattern is printed as shown below. After printing, printer exits the SelecType mode and return to the READY status.
Nozzle check pattern examples:
good
yoi.gif head cleaning necessary
headcleaning: press the cleaning button for 3 seconds
Feb 10, 2010 | Epson Stylus Pro 9600 InkJet Printer
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
New black ink cartridge won't print correctly
It can take some time to get the ink through.
I would suggest do the head clean at least 3 times if you then do a nozzle check and notice improvement then you are on track.
If it does not improve then it has been standing to long and not good news, this I am not willing to be the barer off.
(printer may need to go to heaven)
Keep in mind head cleaning is an ink eater so only do as you need.
Let me know how it goes.
Regards Craig
Feb 03, 2018 | Epson Stylus Photo R320 InkJet Printer
Epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
No black
Hi good day try to head cleaning twice and test print nozzle if colors complete try again printing pictures.
May 01, 2008 | Epson Stylus Photo R320 InkJet Printer
Not printing in black
Turn off the Stylus CX. Load letter-size paper in the sheet feeder. Press the ink and ON buttons together and hold them down for about 3 seconds.
The Stylus CX turns on and prints a test pattern, which includes a nozzle check. If the print comes as = >
Nozzle check pattern with no gaps, and if its print in black then reinstall the printer driver
or => Nozzle check pattern with gaps and black doesn't print please send the printer for repair
Sep 19, 2007 | Epson Stylus 680 InkJet Color Printer
Epson Stylus Photo R320 InkJet Printer Logo
423 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
