Question about Kodak EasyShare C643 Digital Camera
My Easyshare 643 turns on but the display is not normal. there is a black swallow like figure on the rhs. It still flashes when you press the shutter but I am not sure whther anything is happening
  • 157 Answers
Sounds like a damaged lcd screen without actually seeing it. send a photo and i can confirm it.
Posted on Jun 16, 2009
It does not take pictures or videos when pressing the shutter button
may be you had placed the card wrong and inside the pin got pressed and only inner memory is getting used which gives less pic. due to less mb inner memory
Apr 26, 2013 | Kodak EasyShare C913 Digital Camera
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
When i turn my camera on the screen is black. when i take a picture the screen remains black and when i press review of the picture i took that is black as well. is that a back light problem or something...
Try downloading the picture to your computer to see if it is also black. If so, then yes it may be a shutter issue. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 21, 2010 | Kodak EasyShare C330 Digital Camera
My Kodak EasyShare C713 suddenly takes only black pictures and shows only a black image on the LCD in live display. Playback is fine for old pictures and movies. Can I replace the picture senor element-...
It actually might just be a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
Dec 19, 2010 | Kodak EasyShare C713 Digital Camera
I have a Kodak EasyShare M340 it was working fine earlier today but now when I turn it on the screen is black and when I take a picture it comes out black too, even with flash I can see the saved pics on...
Nov 20, 2010 | Kodak EASYSHARE M340 Digital Camera
Can't figure out how to use the timer on my Kodak C613 Camera . The instructions show the self-timer light but doesn't explain how to turn it on.
Press the Menu button, use up/down to select "Self-timer," choose an option, then press OK. To start the self-timer, press the shutter release button as normal.
Jun 16, 2010 | Kodak EASYSHARE M1063 Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
Display not working
if shutter is working it is the dfective CCD so replace the CCD.
Apr 03, 2010 | Kodak EasyShare C533 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
My Kodak Easyshare LS443 is taking black pictures
Dec 15, 2008 | Kodak EasyShare LS443 Digital Camera
Kodak EasyShare C643 Digital Camera Logo
81 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
