Question about Pinnacle Dazzle DVD Recorder
Dvd recorder im having similar problems with my recorder but the thing is mine just wont record i have all the double ended av cables and i have the 3 way spiliter ive plugged it all in but when i pick to record it does nothing
  • 255 Answers
1. uninstall your pinnacle software
2. uninstall your pinnacle card
3. fix your pinnacle card in another socket
4. re-install your pinnacle software
5. check all your settings in pinnacle software
before you record & check the location
where do you want to store the recording.
6. hope this will work out
thanks.
Posted on Jun 16, 2009
Xbox360 Recording Problem (With DVD Recorder)
FixYa, stop asking me to fix Xbox 360 problems, I DON'T OWN ONE NEVER HAVE. Also I don't care about other people's problems, just mine.
Apr 06, 2014 | Microsoft Xbox 360 Console
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Dubbing from vcr to dvd
Bets solution is run av cables and not RF male to female.. AV out of VCR to AV in on DVD rec. Check in menu or at back of vcr for sountsetting like BG,I, DK etc and check also on DVD rec that its the same
Aug 02, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
SETUP ADVICE NEEDED TO INTERFACE WITH MOTOROLA DCH 70 CABLE TUNER
Take a splitter from the wall and plug it in using a seperate line. You wont get all the digital channels but you can get channels up to 150 to record. Depending on how many av outputs you have on the back of your digital tuner you might be able to take one of those those and plug it into the av input of your DVD recorder. You can get a better picture that way when you record from the cable box vs using coax.
Make sure the splitter is approved for digital cable use. The Radio Shack ones work the best and they are usually the same version of the ones Comcast sells to customers. If you get a brand like they carry at drug stores you will lose picture quality and probably end up with a service call bill as well.
Aug 04, 2008 | RCA DRC8320 DVD Recorder/VCR
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
Problem connecting Samsung DVD-HR737 DVD recorder to Set Top Box
I had the same problem, if you go through the channels from your DVD-R remote it should give you the option AV-1 and then AV-2 ? on mine it's AV1 (test it out first and you have to watch what your recording) then it should record from the cable box
worth a try?
May 17, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Can't find source
The very same problem i am having, If you find out please e-mail me @ ulcard35@yahoo.com In subject please type DVD PLAYER..Thank you for your help
Feb 20, 2008 | TruTech T650-DR DVD Recorder
Cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Pinnacle Dazzle DVD Recorder Logo
132 people viewed this question
Top Pinnacle Computers & Internet Experts
Alun Cox
 Ian Kayhan
Ian Kayhan
Josh Levin
Josh Levin
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
