Question about Sharp AR-164 Copier
My name is xptareq my copier Sharp AR 151 busy light blinking
My name is xptareq my copier Sharp AR 151.when maky copy then busu lamp is blinking long time i am not finish copy please help me .
  • Sazeed Computer
    Sazeed Computer Jun 21, 2009
    What is the no of code toner lavel chach
    Problem Solver:
  • 5 Answers
U check toner level
Posted on Jun 16, 2009
Sharp ar-501 Code H3-00
Heat roller abnormally high
temperThermistor defect
MCU PWB defect
Fusing connector connection failure
Power supply failure
atureCheck the heater lamp blinking
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
MCU PWB.
Clear the trouble with SIM 14
Jun 18, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 151 E7-15 error
copy lamp disconnection trouble - copy lamp or cpy lamp drive circuit (inverter PWB) trouble copy lamp disconnection. If lamp does not light when you power up machine, the lamp is burned out or board is bad.
Aug 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
I have problem in Sharp AR-M205,and i don't know how to fix, error code F5
F5 00 Content Copy lamp lighting error Detail Copy lamp does not light despite the output of lighting signal. Copy lamp lights without the output of lighting signal. Cause DC power supply defective Control PWB defective Copy lamp defective Improper connection of harness between PCU PWB, DC power supply unit and copy lamp unit Check and remedy Check copy lamp for lighting with SIM5-3. Check harnesses and connectors between PCU PWB, DC power supply and copy lamp unit
Jan 12, 2010 | Sharp AR-M205 Copier
My sharp ar5516 blink f and 5 what should be the problem
Hello sir; Try to make a copy while lift up the cover, if scan without light. it means the exposure lamp defective, replace it will take care the peoblem.
Dec 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-c330 with an error code of H4-01. Any
The fuser temperature is low.
Use sim. 5-02 to check blinking of the heater lamp.
if it blinks normally check the thermistor and the harness.
If it not lighted check the heater lamp and thermostat if its defective replace the heater lamp or the thermostat.
Jun 10, 2009 | Sharp AR-C270 Color Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-151
E7 15 copy lamp disconnection : Copy Lamp Drive Circuit
you need a tech to replace the circuit board for the scanning lamp
can not be reset
26 = 2 & 6
39 = 3 & 9
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-151
E7-03 LSU problem (laser unit) E7-04 CCD white level problem E7-05 CCD black level problem E7-12 Shading problem
Sharp AR-164 Copier Logo
154 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
