Question about Ryobi 18-inch Electric Chainsaw Chain Saws
I dont know what to use to remove the cover to remove spark plug , is it a allan key or philips screw driver & what size thanks jim
    Sergeant:
  • 384 Answers
There no spark plug on an electric chainsaw.
Posted on Jun 16, 2009
2 Suggested Answers
  • 384 Answers
SOURCE: i dont know what to use to remove the cover to
Most likely it is a Torx head type screw. Looks like a cross between a Allen & Philips. Go to your local hardware store or auto supply store and get a Torx driver with exchangeable bits (about $4.00)
What is the Torx socket size for spark plug cover?
you dont unscrew the cover,you pull the plug wire to access the plug and then use an extension with your socket
Jul 11, 2015 | 2000 Cadillac Catera
Need to know how to replace spark plugs and wires on a v6 mazda 2001
All you need is a deep socket that is the right size to fit your spark plugs and the new set of leads.
Spark plugs:
remove the spark plug end of the lead, use a screw driver and rag to place down the whole to mop up any oil that may be down there. remove your spark plug, place the new one in and replace the lead. simple as that really.
Leads:
These can be more difficult. As you pull the leads off the park plugs and distributor you will need to take note of which lead goes where and write it down. once all 6 are removed just simply reverse the process. A good rule of thumb is the length of the leadas to its location on the engine but dont take it for granted.
Oct 22, 2013 | 2001 Mazda MPV
Try to replace spug pluks but i dont know how to remove the cover , please i need help thank you.....
REMOVE TOP ENGINE COVER,REMOVE THE TTHREE TOP PLASTIC PLUGS ON TOP OF COVER WITH SMALL SCREW DRIVER TO ACCESS THREE SCREWS RETAINING THE ENGINE COVER.
Jul 27, 2011 | Volkswagen GTI Cars & Trucks
Removing on/off shower handle, use an allan wrench i know, but can't seem to see to screw thru the opening and determine size of wrench to use. any suggestions?
If you can not see the set screw with a light you will need to just try allan wrenches until you find the one that fits.
I know that's not what you want to hear but with all the different sizes out there and then add in the metric stuff it is impossible to now what size your working with.
I went to the american standard book and over the years they have used 9 different sizes some metric and some standard us.
Mar 02, 2011 | American Standard One Handle Shower Only...
What is the procedure to changing an keyed ignition lock?
Removal
Disconnect the negative battery cable with the proper size wrench and place away from the battery.
Insert the key into the ignition lock cylinder and turn the key to the run position.
Remove the steering column cover on a tilt steering wheel model by pressing the upper and lower section of the cover together and pulling free from the mounting plate. Remove the steering column covers on a non tilt steering wheel model by using a Philips screwdriver and unscrewing the mounting screws.
Disconnect the electrical connector from the ignition switch by lifting up on the release tab and pulling.
Press the ignition switch actuator pin by pushing a small screw driver into the key lock cylinder, while doing this pull the ignition switch out of the ignition switch housing.
Installation
Insert the new key into the new ignition switch and turn the key to the run position. Insert the new ignition switch into the ignition switch housing. Wiggle the switch back and forth until the actuator pin mounting hole is aligned and falls into place.
Install the electrical connector back into the connector housing by pressing it in with your hands.
Place the steering column covers back onto the non tilt steering wheel and insert mounting screws. Tighten screws using a Philips screwdriver. Place the steering column covers over the tilt steering wheel and press the upper and lower portion together to snap covers back into the mounting plate.
Pull on the ignition key to ensure switch is locked into place. Turn key to the "off" position and remove the key. Insert the key and start the vehicle.
Hope these help.
Jan 28, 2011 | 1992 Ford Crown Victoria
Not getting spark because i loosened the adgustment screws
GAP ON THE COIL ? USE A MATCH BOOK COVER. SPARK PLUG FOLD THE MATCH BOOK
May 25, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Jun 16, 2009 | Ryobi Garden
Spark Plugs
first open the hood and if you look at the engine theres is a black cover, there are two nuts on the bottom and you need a size 10mm socket if im not mistaken, take those off and on the top corner of the black cover there are two little plastic things that you just pop up with a flat screw driver. once all that is taken off pull the black cover up and put it aside. now you can see the 4 ignition coils because it dosent have spark plug wires. to get to the sparkplugs you need to take out the ignition coil. you need to remove the screw it is a 10mm socket i think and once you remove the screw disconect what ever its conected to and just give it a twist and pull it up and if you peak in the hole the spark plug will be right there.
Aug 05, 2008 | 2000 Toyota Corolla
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
85 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
