Question about kawasaki Full Suspension Mountain Bike Men
No gauges and no lights
Kawasaki 1988 Voyager XII...
Radio, Fog lights, signal lights and parking light only things electrical working. Was intermitent but now constant. All the gauges and tach. do not function and no brake or running lights.
Any ideas, greatly appreciated.
Alfred
    Sergeant:
    Champion:
  • 214 Answers
Check the battery terminals, it might have been displaced or else there would be some lose connection..............have a nice day :-)
Posted on Jun 16, 2009
2001 kawasaki voyager 1200 remove front cooling tube off engine to replace o rings...how do you do this
Hi, Scott for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.amervoyassoc.org/forum/viewtopic.php?t=7993
Kawasaki Voyager XII fairing removal
Kawasaki Voyager XII Service Manual
OEM Parts for Kawasaki
http://www.kawasaki-techinfo.net/showOM.php?view_lang=EN&spec=US&book_no=99920-1983&lang_code=EN
Feb 14, 2017 | kawasaki Motorcycles
1986 Kawasaki voyager xii stopped for gas then push start button has nothing push starts up
Hi, Steve and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty kickstand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
American Voyager Association
Thread Starting problem
Kawasaki Voyager XII Service Manual Page 3
May 18, 2016 | kawasaki Motorcycles
How do I replace the speedometer cable on A 1994 kawasaki voyager XII
It is usually possible to replace just the inner part which can be purchased as a universal kit and trimmed to fit. Lube it as you install it this is much easier than replacing the whole thing.
Feb 20, 2015 | kawasaki Motorcycles
Kawasaki Voyager xii 's cruise set light stays on,the bat light stays on and the neutral light will not light
the computer in you vehicle tell them when to come on and off. you might wanna get it tested.
Dec 28, 2012 | Cars & Trucks
1988 jeep comanche wiring
drove mine to the ends of the earth,
there are 4 books,
big main , engine,and one for trans, no PDFs back then so, none sold. just paper books.
its and old car, very old, not too many left run 1988
with that nasty French REniX EFI system/.end rant
I had the 1988 XJ too, a pair of jeeps. then....
i can see your wiring is all messed up
and grounds.
got a voltmeter,
if not only guessing and wire inspections may work
ever consider get a sparks guy to fix it? He can and easy.
I promise.
for me to teach you electrics in this box, is over the top hard.
id have inspected all those wires, every inch
and #1 is trailer wiring hacks at the rear.
the tails are not tails
if you its Parking lamp after the front parking lamps or side markers can not be called TAIL,but yes, some fuses are still using the old 1884 now TRAIL name
check fuses yet, means test them ones that look good test.
using a METER.
.i see there are shorts on the KEY switch IGN out pin
for sure.!! radio is off key OUT and off.
or that wires IS SHORTED
harness messed up near steering/cluster,big time.
Feb 28, 2017 | Jeep Comanche Cars & Trucks
2002 Voyager xii on warmer days when coming to a stop the engine goes into a high Idle 2000-2500 rpm. Dragging the clutch enough to slow the engine down will make it idle normally until the throttle is...
Hi, Vetter596 and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector.
10. Multiple carburetors not in sync.
2003 Patrol RPMs will not drop to idle when warmed up
1989 Kawasaki Voyager XII Owner Manual
Jun 15, 2017 | kawasaki KZG 1300 Motorcycles
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Need a (free) wiring diagram for headlight on 91 Kawasaki Voyager
try this site http://www.manualz.info/
they have mauals online for a lot of bikes.
hope this helps
Jan 02, 2009 | 2001 kawasaki ZRX 1200 S
kawasaki Full Suspension Mountain Bike Men Logo
187 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
