Question about Refrigerators
Fridge freezer Last tuesday I was sick and haven't felt right since. we were wondering if it's the fridge and freezer we've got as when we first started getting the warm wether our fridge seemed warm none of the food or drinks were cold, since then I turned it up to 3.1/2 dial is only 1-5. I think at one point the freezer hadn't much ice in it but I didn't think any thing of it. My partner said last week there was alot of water in the fridge and thinks maybe it's self defrosting. Is this right and how often should we be defrosting the fridge and freezer it's a candy make I don't know the no: Can you get fridge poisoning as i jut don't feel well and the food now doesn't taste right. Please please help.
  • 159 Answers
It seem to me that the gas lewel are low in the system
Posted on Jun 17, 2009
Igloo mini fridge not getting cold
The compressor may be frozen. Turn off the fridge for 6-8 hours, then turn it back on. Don't turn the temp to the coldest setting. If it will still not get cold, the compressor is probably bad.
Jan 22, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
Servis Fridge Freezer Model # M7973B-I/1 light flashing
Likely problem is the temperature setting control is failing.
Apr 04, 2012 | Refrigerators
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
Fridge freezer HNMF2805-80. fridge is freezing
isnt that the highest you could put it. how about taking it down to 1 or 2. it should say on the nob.
Jan 28, 2010 | Hoover Refrigerators
Our freezer and fridge just quit working too
It sounds like the thermocouple has gone faulty. This is part of your temperature control system. Best to have it checked out by an appliance repairman. Good luck, Dana
Sep 07, 2009 | Refrigerators
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
Fridge getting warm, defost not properly working...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Danby Designer DAR1102W Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
