Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Problem with TEKA DW6 40FI
Hi, my dishwasher, for which I had the pump replaced only recently at great cost is no longer working. This time it stopped before pumping out the water. So to clear the water I tried to run the programme again and it did drain the water but then started sounding the warning sound (the sound it normally makes when the programme finishes) and the 3 lights of the various programmes keep blinking simulaniously. I've tried turning it on several times but now it does not run any programme but just keeps making the sound every few minutes and the 3 led lights blink (all 3 at same time). I've taken it off mains power and tried switching it on and off but that does not seem to make any difference.
I've been trying to get in touch with Teka technicians to find out what it means when my machine is doing this but the service centre won't help me over the phone to shed some light on this. They will send out a technician for a rediculous £149. I just need to know if there is a fix or if I should throw my machine out (as the repairs are costing more than buying a new one). If there is anybody out there how has come accross this before please let me know! Thanks.
  • 1314 Answers
SOURCE: Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Posted on Jan 31, 2008
SOURCE: teka dw6 55 FI, error
its not draining
Posted on Sep 22, 2008
abhishek33
  • 1239 Answers
SOURCE: Teka Dishwasher DW6 59 FI
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 13, 2008
  • 3247 Answers
SOURCE: Teka DW6 59 F1 Lights 4&5
I am slightly unclear if lights 4 & 5 are counted left to right or right to left when facing the dishwasher.
If you are counting right to left - then lights 4 & 5 flashing implies E3 fault - heater failing to heat.
am suspecting the heater unit is failing. Try to run dishwasher on a colder program like DELICATE and see if goes through.
If the flashing does not go away by turning power off and back on then the heater or the thermostat has failed and will need replacement.
Hope this helps fix the problem. Please post a comment if this is not helpful.
Posted on Mar 17, 2011
SOURCE: need an english manual for
By maggiegardne on Nov 20, 2010
need an english manual for teka dishwasher dw6 59 f1 please
Posted on Mar 30, 2011
Hi my teka dishwasher dw7 56 fi makes a noise when first switched on .
what is it supposed to do . be so quiet you can not hear it working .
Dec 07, 2015 | Dishwashers
How do I fix a Teka DW6-59 dishwasher thermostat problem
If it heats and fills, would not think thermostat, tstat checks that the temp is ok, then prog moves on, If tstat, would never move on. think more after that, maybe, does the pump work, could be broken wire power to pump, can you hear the pump working, if continuois cycle, at what point does it stop and start at beginning, does it pump water out? if not water level sensor.
Jul 29, 2014 | Dishwashers
The pump in my Miele dishwasher is not working. What would it cost to replace the pump?
Hi, the cost of getting a Miele dishwasher pump is not really expensive which i around $90 and if you are handy enough, you should be able to replace it yourself. Getting a technician to fix it won't cost you more than $50.
You can get the pump HERE
Jun 26, 2011 | Dishwashers
Need an english manual for teka dishwasher dw6 59 f1 please
Nov 20, 2010 | Dishwashers
How do u clean the pump and drain hose on a teka dishwasher? please help
buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
THis should help clean the pump and drain hose.
It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
I tried this site
http://instructionsmanuals.com/lista2-20-49-en-Dishwashers-Teka.htm
but they all seem to be in European languages.
May 25, 2010 | Dishwashers
Dishwasher will no longer drain completely
The pump is bad and needs to be replaced. The pump is not pumping out all the water from the system
May 05, 2010 | LG 24 in. LDF 7811 Stainless Steel...
How to reset a dishwasher teka lp700
i have a problem with teka lp 700, dial gets stuck and water starts to spill out, also the motor after awhile ceases up.
Apr 19, 2010 | Dishwashers
My teka dishwasher does not drain properly and there is water left in the bottom after the cycle has finished
Means that your pump is obstructed. Clean the filters out and if tha does not work clean your pump and drainhose.
That will solve your problem
May 01, 2008 | Dishwashers
Bosch dishwasher she44c02uc runtimes are getting longer
hi there this is a software problem on the pcb and the only way to fix it is to replace the pcb. cost about £80
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
169 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
