Question about Cuisinart Coffee on Demand 12-Cup Coffeemaker
Cuisinart Coffee on Demand?12-Cup Programmable Coffee
Our coffee machine will not brew. The machine heats up but the water does not go anywhere. We have tried tunning the machine on and off but it still will not brew!! : (
  • Anonymous Mar 28, 2014
    I have an issue with my Coffee machine where whenever i select one of the functions related to Milk Jug Cappuccino, Late etc it says heating up and nothing happens. took it to a service shot and they said it needs a power control model as the one i have is faulty. is there any codes i can try to diagnose it and is there a hard reset i can do for the machine please?
  • 85 Answers
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
I have a Cuisinart Coffee on Demand that leaves about 1-4 cups of water in water reservoir. What is causing this.
Posted on Aug 06, 2009
  • Marci2 Dec 29, 2010
    Mine is doing the same thing.....what can I do? Clean it? It's only 4 months old.
Owned this coffee maker for 14 mos. At first you'd turn the brew switch and the brew cycle would start. Over time you'd turn the brew switch and it would take awhile. Now who knows when it will start.
Over time, Calcium will deposit on the tubes and containers which get in touch with water. Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water. .
Jun 19, 2015 | Cuisinart DCC-2000 Coffee-on-Demand 12-cup...
Coffee Maker is leaking
mine was not same make but the upper water tank was plastic and seems they fracture when getting hot too many times .Bunn would not provide a replacement tank so it was buy NEW
Jan 08, 2015 | Cuisinart DCC-3000 Coffee-on-Demand 12-Cup...
We have a Burr Grind & Brew 12-cup, programmable Cuisinart. Even with the vinegar solution, it seems to clog more than we expected. We have a water softener. Tired of making 8 cups and only getting 5...
you must physically remove the lime.
first remove the spray head and then brew the coffee in an empty waste container.
remove all the lime as much as you can.the hot water force the lime to go out .
IF YOU HAVE DELIMING SPRING THEN IT WILL WORK GREAT
thanks
please rate my work
Sep 05, 2011 | Cuisinart GRIND AND BREW COFFEE MAKER
My machine doesn't brew - the water doesn't flow through: why?
i have a 12 cup programmable cuasinart coffee pot sometimes when i turn it on it will brew right away and sometimes it takes forever to brew. what could be the problem?
Nov 13, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a Cuisinart Coffee on Demand maker and it will no longer brew. Its less than a year. How can it be fixed?
mcdevito75 here, May need to be cleaned a swater will leave deposits, refer to owner manual for cleaning.
Jun 22, 2010 | Cuisinart Coffee on Demand 12-Cup...
Coffee Makers & Espresso Machines Logo
1,222 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
