Vulcan Oil Heater not operating correctly
I have the same Vulcan Oil Heater (Model 10-05). The heater had been working well but recently has problems starting. I have tried the obvious things but nothing has helped.
Is it possible to get a copy of the manual or other documentation on the heater. I note that John (veewee) has managed to obtained a copy of the schematic diagram.
  • PeterM65 Jun 21, 2009
    On advice from FixYa, I opened up the heater and removed the oil burner box. I then cleaned out the coke and soot before re-assembling the heater. The heater then started first go and in a much shorter time. Thank you Madsensve (FixYa).
  • 3 Answers
If the red light comes on when starting, this means that there is continuity in both exhaust heating and igniting elements and the heater cutout is also working.
The most common problems with this heater is coke & soot build up in the bottom oiltray and clogging the bottom air intake holes, to remove this the heater box has to be dismantled.
Posted on Jun 18, 2009
Where can i get heating filter (ceremic?) replacement parts for an old vulcan heater?
Do you know the model heater?
Can you post photo of the filter?
I have some filters for Vulcan oil heaters
Aug 18, 2011 | Vulcan AUW230A Heater
Just installed a vulcan oil heater, but when you start it up it will only burn yellow flames and keeps going out and will smoke, then relight with a bang,
Sounds like you may have the wrong size tip on your oil burner. A yellow flame indicates too much fuel not enough oxygen.
Jun 08, 2011 | Heating & Cooling
Trouble starting an vulcan oil heater
Are you able to post a picture/photo of the heater. I may be able to give lighting instruction.
where are you, I'm in Adelaide SA
Oct 25, 2017 | Vulcan AUW230A Heater
Require replacement glass for old vulcan oil heater
Hi ddsalm,
Did you ever recieve an answer to this?
Jun 22, 2010 | Heating & Cooling
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Vulcan 11 fin coil oil heater. it just stopped working.
The heater should not have been affected by the what the maid had done. Turn off the power to the heater and let set for a bit, Check your thermostar settins, turn all the way dow and back up to what you want set the timer and give it a chance to heat up again. There might be a reset buttun somewhere so look around. I bet its cold in Austrailia right now.. Good luck-Ned
Jun 12, 2009 | Heating & Cooling
Vulcan oil heater
Regarding the wiring on my ancient Vulcan oil heater...I have only just received a wiring diagram (dated January 1969), which I am just about to get stuck in to. I hope that I can follow it (the drawing looks like the last copy of something that's been copied 1,000 times before on one of those old Roneo, wet ink, wind-it-by-hand copiers). The drawing came from a Vulcan agent on the very far side of Adelaide. Here's hoping. Ooroo, John. .
May 27, 2008 | Heating & Cooling
Would like to know the wattage oiutput on my vulcan duel fuel oil heater
¿ Oil heaters do not generate wattage. On the name plate for the unit it may give you an AMP draw. Multiply Amps times Volts to get wattage use when in operation.
May 01, 2008 | Heating & Cooling
Vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Mar 26, 2008 | Heating & Cooling
Heating & Cooling Logo
920 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
